ok so my eclipse ti 15 rattled something loose or something for the wiring of my deck so the other day i turned my car off(it ran no problem) i pulled the deck out there was a black wire i had to retape and i checked my stereo fuse(not blown) then when i went to restart my car it would turn over but not start! help! if anyknow might know or has had this problem before it is a 98 civic dx hb if it matters
OH and anouther question im building a new box for my 15" eclipse ti its on a zx1000.1 right now hoping to get my mojo mc2000d back.. for it but im going to build at about 36l 16h 18w and i want to tune LOW
well, you will need to do some meter work. Do you have power at the dist. when cranking? if yes, then check pick up coil in dist. If not, do you have juice at main coil pack? if no, then its the pcm likely. Or some security thing with the car.
CAR IS GOING! a fuse was bent the slightest bit for the coil! ok but now looking at box designs i desided screw the rear seats so give me a box that will make my eclipse titanium PUMP! 15" please and thank you i dont really want to go over 4 cbs but if i have to cya seats!
ya was low budget at the time i just went through everything used connectors all good again im building this box soon here thinking early this week soo pumped sub/port facing roof of the car?
