Rockford Fosgate vs Cerwin Vega
Username: Grampa
Post Number: 7
Hi all,
I'm looking for a nice budget quality amp for an Eclipse SW6210. I need an amp that will do around 500rms @ 2ohms. I've had a look around myself and I've narrowed it down to 2 that I think would be a good cheap solution.
Cerwin Vega V500.1: http://www.sonicelectronix.com/item_12078_Cerwin-Vega+Vega+V500.1.html
or
Rockford Fosgate Prime R500-1: http://www.sonicelectronix.com/item_17368_Rockford+Fosgate+PRIME+R500-1.html
Please let me know which one you think would be best for the job :-)
Thanks everyone.
Username: Skdooley
Roanoke, VA Usa
Post Number: 124
I've ran fosgate amps and they've always done great. I'd recommend the RF.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 175
Between the two id go with the RF. You might also wanna check these out 2. http://www.onlinecarstereo.com/CarAudio/p_19251_Alpine_MRP-M500.aspx http://www.onlinecarstereo.com/CarAudio/p_19219_Kicker_08ZX5001.aspx
Username: Grampa
Post Number: 8
Thank you both for your opinions :-)
And thanks for the recommendation Sean P. The Alpine looks good too. Would you choose the Alpine over the RF? I think the Kicker is a tad too expensive for me.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 179
Yea,i think if it were me i would go with the alpine.RF aint what it used to be,and kicker is expensive.Not to sure about Cerwin Vega amps,ive only ever had there subs.
Username: Grampa
Post Number: 9
Ok thanks man.
