Wharfedale diamond 9.6 vs Boston Acoustics vs Polk Audio
Username: Dheeraj
Hi guys,
I am buying my first hifi system at the age of 45 yrs. The money is hardearned and i am really splurging.
Somehow I have selected Marantz PM 7001(Rs 24,000) amp and Marantz cd 5003 cd changer (Rs 18,000). I need to finalise the speakers between Wharfedale (9.5 for 28.5 K and 9.6 for 36 K), Boston Acoustics and Polk Audio. I am currently not buying a sub as I canot afford it.
All u experienced audiophiles help please....
Is my choice of the Amp, CD player at this price ok ???Will the amp drive the 9.6 diamonds wee
Username: Dheeraj
which model of Denon amp matches with Marantz 7001 and what should it roughly cost in India.
I listen to a wide range of music and basically looking for value for money. Is there a better combination you can suggest at this price
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3293
Scratch the Polk off the list.
Username: Dheeraj
Thanks dave so do u think the Marantz 7001 with marantz 5003 source and wharfdale 9.6 diamonds are ok for an entry level hi fi system.
Also does bi wiring help......
sorry am a bit of a rookie
Username: James_the_god
Lancaster, Lancashire England
Post Number: 822
How did you arrive with the Maratnz 7001 as a choice? I can tell you its a very nice amp although discontinued but like that matters!
I heard it with some Acoustic Energy floorstanders, perhaps you should look at some too!
Biwiring I dont bother with. Personally find replacing the jumpers (links between binding posts) with good cable does the trick for that. And other areas like positioning, isolation etc are far more benefitial to noticable improvements.
Wouldn't recommend your cdp choice though, perhaps a better Marantz model like the cd6003 or rotel rcd-06. Marantz I find are especially different in quality between models.
Username: Boulderdashcci
Canton, Massachusetts USA
Post Number: 117
The CD5003 isn't a changer, it's a single disc player.
