How to wire 2 ohm
Username: Sgreer
Im getting 4 Infinity Kappas 63.9i speakers. I am running them off of a Alpine MRP-f300 amp. The Infinity Kappas are made to run at 2 ohms. If they are supposed to be ran at that, do i still have to wire them parralel to get the 2 ohm load? Or will wiring them parallel make it a 1 ohm load?
Username: Nick_belsky
North Canton, Ohio USA
Post Number: 34
Trying to help you out on this but I can't find any wiring info anywhere on this particular speaker. Here is the link to Infinity with some info:
http://infinitysystems.com/car/products/product_detail.aspx?prod=KAPPA63.9I&Chec kProduct=Y&Language=ENG&Country=US&Region=USA
You may have to give them a call for detailed info.
Or call CS and ask for Technical Support at 800-553-3332 for the US.
Hope that helps.
