If ur kbox is down read this...
Username: Saqeeb9000
Post Number: 6254
from kbox loader...
• No need to any change on your settings.
• Maintenance in progress to fix current network outage.
• Soon service will resume
• We appreciate your understanding.
a
so solution is relax and don't plug out anything.
it will be fixed when maintenance will be over..
Username: Kowarrior1980
Post Number: 16
Thanks. Also, why does the kbox go down so often? Can't they find a way to fix this issue? Everyday, it goes down at some point.
Username: Sump
Post Number: 876
yes the loader message been there since last evening ..
thanks sada ..
Post Number: 6255
u are welcome.
no it uses iks,
so there will be issues,
its not easy to make server stable,
and its normal with any iks rec,
problem occurs when too many people watch tv at same time with iks,....server gets over loaded,
did u notice when it gets down,
normally on weekend, evenings or any holiday.
Post Number: 17
I've noticed it go down at 1pm in the afternoon when everybody should be at work. LOL!
Username: Nydas
Post Number: 16591
Version 212 is out.
It is a required non-optional upgrade.
k1pro_212_20091111.zip
It is not yet available at the currentbins site.
Username: Kboxuser
my kbox is also down
and red light on khub.
i guess everyone has the same issue, am i right ?
Username: Sump
Post Number: 891
No up and running go to
www.kboxforum .com live support
Username: Kboxuser
go to http://kboxkhub.org/
download file and extract in usb drive
plug in usb drive to rec.
allow it to upload file (just press 'ok')
it'll restart than take out usb drive.
Go to
Menu--> Cong.--> Network
It'll take time but will show 'OK'
restart kbox. rec.
