Poor signal quality!!
Username: Yalfaress
Post Number: 22
Hi everyone:
I finally was able to get a maximum of 40% quality on my cw600 receiver from galaxy 19(97.0 W) I downloaded all the channels into the receiver, and most of them worked for a while. Then they all went scrambled except for Al-jazeera English Channel. I tried to adjust the skew and focus on the LNB to get a better quality, but without any success. In addition, I tried to move the dish up and down and right and left to improve quality, but also without any success as any slight movement of the dish would result in the reduction of quality to 0%. How can I improve the quality to get to watch the channels on my TV. Will a signal amplifier help?? or are there any other suggestions to solve this problem? Please note that the dish view is very clear with no apparent obstructions.
Username: Shenanigans
Post Number: 258
It's possible your lnb is faulty. Do you have good signal quality on any other birds?
Username: Yalfaress
Post Number: 23
Thank you for responding. I really haven't tried other birds. Any other suggestion before replacing the LNB??
Post Number: 260
I wouldn't replace the lnb until I tried to get a signal on a different satellite. JMO
You could also check your coax and connectors to make sure there isn't a problem there...
Username: Chumley
Post Number: 667
Also, some channels on 97w will be scrambled..
..not every TP on that sat will give you good quality.
When you adjust the dish and get 40% what TP are you using?
On 97w with 30" dish my quality level ranges from 82% to 28%.
Even the 28% is watchable with no break-ups, - (cw600s)
Username: Nydas
Post Number: 16535
Chumley watching Iranian TV!!!
She must be a double agent or something.
Username: Dibblydooda
Post Number: 44
Yaser, don't forget about weather.
If you are at 40% sometimes cloudy weather can make a difference, but I would check my connections, terminate unused connections, and check your desq switch.
Username: Yalfaress
Post Number: 24
chumley:
I am getting 40% quality on 12152/H/20000/3/4. On the rest of them I get less than that, even 0% on some of them. The cable and connections are good. Would a signal amplifier help???
Post Number: 45
Yaser I'm not sure if Chumley will agree but the only signal amplifier I would use would be a larger dish or an LNB with a lower noise ratio than the one you have.
I personally would go with a spitfire elite LNB it is fairly inexpensive, less than $20.00 and has a .1 db ratio.
Post Number: 46
I forgot to note that if you do have a cable run of a 100ft or more then a signal amp might work.
Username: Chumley
Post Number: 668
TP 12152 is one that has the highest quality reading on my cw600s setup at 72% (earlier i posted 82% as high Q. - actually it's 72%)
Check here to see recommended dish size for your location
http://www.lyngsat-maps.com/maps/galaxy19_namku.html
Username: Nydas
Post Number: 16537
A signal amplifier will work if you place it near the LNB.
period.period.period.period.
Username: Nydas
Post Number: 16538
The order of importance to you for better signal.
1. Larger Dish.
2. Better LNB.
3. Signal amplifier.
You might have to postpone item 1 because of costs and convenience. Item 2 is easier, but item 3 is easiest to try although least important in the heirarchy of usefulness.
in the heirarchy of usefulness, chumley is the least useful person on this forum. Her main aim is to disrupt and obscure the real helpers like Plymouth. Ole McDonald is a newcomer and seems to be posting rationally and intelligently so far.
Username: Gregraf
Post Number: 3861
At least justforhaha's has style unlike you Nyda you Mole and Rat.
Username: Justforhohas
Post Number: 64
Nalin Nyda.........chumley is the least useful person on this forum
DO NOT use profanity or demean your fellow users.
chumley knows more about FTA TV then you will ever know.
To the Mole in charge here now, why did you deleted my thread ? I broke no ecoustics rules and
Nalin Nydass who has broken ecoustics rules his thread is still here?
This is a Public forum and the members here have a right to know.
Username: Nydas
Post Number: 16542
justfarhaha's: You are just boasting about yourself. Everybody on this forum knows that.
Username: Plymouth
Post Number: 11594
justfarhaha's
Post Number: 64
I gived you a advertizing, but it seems that you not understand it!
Post Number: 66
Nalin Nyda
Username: Nydas
Post Number: 16538
Posted on Sunday, November 08, 2009 - 11:54 am:
1. Larger Dish.
2. Better LNB.
in the heirarchy of usefulness, chumley is the least useful person on this forum.Her main aim is to disrupt and obscure the real helpers like Plymouth. Ole McDonald is a newcomer and seems to be posting rationally and intelligently so far.
Username: Plymouth
Post Number: 11596
Yes Cumley is very good as good that he give RTN on 93W when those channels are on Galaxy 3C 95W.
Good comment idiot!
https://www.ecoustics.com/electronics/forum/home-video/599587.html
Username: Chumley
Post Number: 670
Keep trying Plymouth..
The Retro Television Network (RTV, previously branded RTN).
It scans as RTN EAST AND WEST at 83w - when I had signal.
Username: Somi
I just buy K Box PRo and 36" dish, please some one help me for indian and english chanals witch satellite i can select,
Thanks
Somi
Username: Plymouth
Post Number: 11597
Somi Tom
You aim your dish on 118.8W!
Do you have a LNB for 118.8?
Post Number: 48
I'm curreny watching The Rifleman on RTNWest 83W the signal is weak. Right now I'm getting 0 to 35% quality. Its still there along with RTNEast.
Somi Tom you might try 97W they have a lot of foreign stations that free and in the clear.
Username: Plymouth
Post Number: 11598
Cumley
You are a joke, on 93W RTN is Russian Television Network which is Dicipher!
Take your pills!
Username: Chumley
Post Number: 672
Playmouth , you brought 93w into the discussion.
Read the thread again !
Username: Somi
Post Number: 7
Yes, i have lnb for 119 and 118 for both and other for 110
thnks
Username: Plymouth
Post Number: 11599
Somi
OK aim your dish on 118.8W first, 119 must work, then aim your 110W LNB.
Use this to aim your dish:
www.dishpointer.com
Username: Somi
Post Number: 8
So its mean i select 97 W (Galaxy 19) for 119 and 118 or (119 echo 7) ?
Anad how about 110...?
Username: Plymouth
Post Number: 11600
Somi
Forget 97W with your LNB you can't get this bird.
Username: Plymouth
Post Number: 11601
Ole McDonald
Give me all info for RetroTV, Tp,SR,FEC, polarity and PID.
I will check it!
Thanks!
Username: Chumley
Post Number: 676
Somi Tom, It may be best to start another thread or post your questions in a kbox thread
https://www.ecoustics.com/electronics/forum/home-video/601409.html
Post Number: 53
Plymouth here is what my system scanned. My system picks up best on low scan, if yours likes hi scan better then add 1000 Hz to the TPs
RTNEAST
Sat AMC 9 / 83W
TP 11738
Polarity H
Symbol Rate 4440
FEC 3/4
Vpid 32
Apid 33
PCR 32
RTNWEST
Sat AMC 9 / 83W
TP 11738
Polarity H
Symbol Rate 4440
FEC 3/4
Vpid 37
Apid 38
PCR 37
Post Number: 54
forget what I said hi and low scan I already added the 1KHz in for the normal 10750MHz scan.
Username: Plymouth
Post Number: 11602
Ole McDonald
Thanks!
I will check it after Nascar!
Username: Nydas
Post Number: 16545
Somi Tom - new member:
Go to the following thread.
https://www.ecoustics.com/electronics/forum/home-video/601574.html
Username: Plymouth
Post Number: 11605
Ole McDonald
Ok Just found both on scanning the Tp 11738.
Thanks
Post Number: 62
No problem, Plymouth.
I'm glad you found it.
It was pretty weak this morning, seems to be OK at the moment.
Post Number: 265
This has turned out to be another top notch thread!
Thanks guys!
