New member Username: Richierich713HoustonUniteed states Post Number: 3 Registered: Nov-09 | serial#113663597 model#39100-s84-a300 Im hoping someone can help me get my radio code. please help as soon as possible anyone |
Gold Member Username: RegroosterPost Number: 2196 Registered: Aug-08 | Why do you keep posting the SAME question on this forum? It is considered very annoying as well as being bad mannered ! A single request is all that is required. If you are that impatient , then contact an online Decode Service who will answer your query by return. --------------------------------------------------------------------- HONDA RADIOS.................IMPORTANT NOTICE PLEASE READ BEFORE POSTING ANY CODE REQUEST ============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on Please note: The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy HONDA radios are made by the following manufacturers ALPINE AUTOSOUND BLAUPUNKT CLARION KENWOOD MATSUSHITA PIONEER The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing UNFORTUNATELY ... NO OTHERS ! So you will be wasting your time posting code requests here for any other make. BLAUPUNKTS ONLY with a BP Serial Number ================================================= For EVERY other HONDA radio made by one of the other manufacturers then visit the website below https://radio-navicode.honda.com If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM) |
