Clarion PU-2294B (D)
Username: Superhetrodyne
Hi Can any one help I need a code for a Clarion
Part No PU-2294B (D)
S/N CL040230882838
Cheers Allan
Username: Regrooster
Post Number: 2186
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Thanks for you advice it look like its a trip to the store. No C70000 number.
Thanks again for your reply
Allan
