Silver Member Username: M0nstarToledo, OH U.S. Post Number: 357 Registered: Dec-08 | im looking for new highs... i have 5 n a quota mounts, not really looking to change it or make pods etc... i cant really find 5.25s that i like everything i find that i want is 6.5 i found these diamond D351, any other suggestions? |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2898 Registered: May-04 | What is your budget? Im on DLS's nuts so Im gonna recommend which ever set you can afford out of these http://www.sonicelectronix.com/viewcat.php?manufacturer_id=210&category_id=73&so rt_order=price_asc Ebay probably has them cheaper though. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 117 Registered: Sep-09 | always depends on what you wanna spend. Hertz has some pretty awesome speakers that you would be very happy with. Ive heard them in a rather large room and they filled the whole room with ease and sound so clean. They are not harsh either. but depending on how much you wanna spend im not sure which model to recommend.. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7378 Registered: Nov-05 | i can second DLS |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15577 Registered: Jul-05 | 3rd for DLS .. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 358 Registered: Dec-08 | on the DLS C5A series should i amplify both tweeter and midrange off the same channel like ive always done? or is that why im blowing all my tweets? and my budget is about 130 max per set, but ill prolly get the DLS C5's |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 4192 Registered: Mar-07 | I used to run D3's a couple years ago. They are nice for 100 bucks. Not sure how much they are now though. I still got 'em too. I would go with something else though. The D3's only come with aluminum tweets and they're kinda harsh. I upgraded to HEX's and it was pretty a much night and day difference. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 119 Registered: Sep-09 | yeah i still have the diamond d3's in my car waiting for enough bank to grab the Hertz HSK 165's. I got a dealer down here that is going to sell me two sets for only $560 BNIB. They are retail price 800 a set. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 359 Registered: Dec-08 | amplify tweeters? yay or nay? |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2900 Registered: May-04 | Not sure what you mean but this is how you should hook up components Unless of course you are running them active but I think its safe to say you are not,no offense. Also you said your budget is $130 per set,how many sets are you planning on getting? I would just buy one good set of comps up front,dont worry about the rear. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 361 Registered: Dec-08 | ^ that diagram is how im doin it. sweet i thought i was doin it right... what is "running them active?" anyways, but when i only have one nice set up front and none in the rear I dont like the way it sounds... its too flat. no surround, unless theres a setting somewhere that would change that.. im in a cherokee so its like if theres no rear sound then its just highs in front and lows in the back and you can clearly tell when sitting anywhere in the car. damn i love car audio. seriously. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2903 Registered: May-04 | Well if I were you I would buy a nice set of comps for front and throw some decent coax in the rear. Amp the comps for front and just run the coaxs off HU and it should sound fine. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 363 Registered: Dec-08 | damn i thought i posted this last night... oh well ill just ask again. would R5 comps be comparible to the MS5 series? |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2904 Registered: May-04 | Im not really sure but I would say that the MS5A comps would be a lot different than the R5s. The MS5A uses a completly different tweeter and the mids are made up of different material. I have the MS6A 6.5s and love them. Mid bass is very punchy and tweet is very detailed without being too loud. If you could up your budget a little bit I really think this is a great deal http://cgi.ebay.com/NEW-2009-DLS-UP5I-2-Way-5-25-Component-System_W0QQitemZ18042 3336658QQcmdZViewItemQQptZCar_Speakers?hash=item2a0211a2d2 Or if you could fit 6.5s these http://cgi.ebay.com/NEW-2009-DLS-MS6A-6-5-2-WAY-Components-System_W0QQitemZ15038 2170741QQcmdZViewItemQQptZCar_Speakers?hash=item230379d275 You could also contact tristateaudio on ebay and see if he has any 5.25 MS5A sets that have not been listed. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 367 Registered: Dec-08 | Ok so i ordered just the C5A comps at 4:30 because i realized i only have 40w rms to work with and dont have any $ for a new highs amppp =[ on the bright side i still got a set! |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 374 Registered: Dec-08 | MAUMEE, OH, US 10/28/2009 12:19 P.M. DESTINATION SCAN MAUMEE, OH, US 10/28/2009 5:31 A.M. ARRIVAL SCAN SYLMAR, CA, US 10/24/2009 1:49 A.M. DEPARTURE SCAN SYLMAR, CA, US 10/23/2009 9:07 P.M. ORIGIN SCAN US 10/23/2009 7:37 P.M. BILLING INFORMATION RECEIVED damnit i want them NOW! It makes me mad to kno that they are just sitting somewhere about 10 minutes away |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 375 Registered: Dec-08 | so i went into work yesterday at 5 upset trhat my speakers still hadnt arrived. got home at 1130, and they were on my bed. i was happy. i installed then at 1 a.m. last night and i have to say, i can see why everyone is on the DLS train. thanks for the help everyone! special thanks to wicked... no h0m0 |
Gold Member Username: BonhamdTraverse City, MI Post Number: 1969 Registered: Nov-07 | mmm h0mos.. |
