Choosing an amp???
Username: Dinger429
I am thinking of getting 3 of the Hifonics HFi12D4 12" woofers (http://www.caraudiodeals.com/hifonics-hfi12d4-p-1784.html) and putting them in a sealed box like this one: http://www.caraudiodeals.com/qbass123-p-129.html. I am new to car audio and have no idea what kind of an amp I would need to run all 3 of these. So, does anyone have any ideas?? I prefer to just get 1 amp because I think it would be cheaper, but if 2 is the better route then I will go that way. I'm not really looking for anything over the top and these don't have to be the greatest of brands. This will be my first system, so I'm just looking for an amp that would make these work. If anyone has a better suggestion for a subwoofer, I'll gladly consider it, but how can you beat less than $25?
Username: Wackzirth88
K-town, Il U.S.
Post Number: 166
if u were to go with 3 of those id go with 3 d2s so u can wire them together and be closer to one ohm. u could run it on a aq 1200d or cheaper less reliable option hifonics brutus 1210d
