New member Username: Lperks69Chippenham, Wiltshire Uk Post Number: 1 Registered: Oct-09 | Ive recently taken my battery off to change it but didnt realise the code was missing i would be very greatful if any one could help Clarion rd1 model: PU-2325A S/N CL0410X0012302 Many Thanks in advance |
Gold Member Username: RegroosterPost Number: 2157 Registered: Aug-08 | The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. (There are usually two barcodes on one label. The one required is the lower one ) Here is a link showing an example of CLARION BARCODE SERIAL NUMBER label, (ignore the Davidson Electronics watermark) http://www.davidsonelectronics.co.uk/images/Serial_Locate/ClarionBarcode.jpg If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) |
