Gold Member Username: DeadrabitMarionville, MO Post Number: 2153 Registered: Jun-07 | ordered from DDM some 6k and 10k... when i got them i got 6k and 3k or something very yellow, just my luck they sent a yucky color |
Silver Member Username: EricmbWaycross, Georgia United States Post Number: 232 Registered: Nov-08 | dang.. HID's look really good. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7395 Registered: Nov-05 | use the 3k for fogs.. |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1868 Registered: Aug-07 | no one cares. are you doing show car stuff now? haha |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7404 Registered: Nov-05 | if you fail at one thing.. move on to the next failure |
Gold Member Username: JtownTexas Post Number: 3953 Registered: Mar-07 | hopefully your not an idiot and at least got projector head lamps.... |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7409 Registered: Nov-05 | thieves ... you should know the answer to that one |
Silver Member Username: 813thumperTampa, FL United States Post Number: 130 Registered: Sep-09 | man you guys are mean.. he may not have listened to you on several occasions but seriously.. lighten up |
Gold Member Username: Philly306If youre going to give... Post Number: 1462 Registered: Apr-07 | you better lighten up guys cuz we all know... internetisseriousbusiness ![]() |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7410 Registered: Nov-05 | orly |
Gold Member Username: Snowball123West Allis, WI Post Number: 3260 Registered: Oct-07 | and thumper. you're next. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2154 Registered: Jun-07 | well i guess i am a big fail.... but for some reason at nationals i got a check and a big trophy that says number one? ![]() |
Gold Member Username: Philly306If youre going to give... Post Number: 1464 Registered: Apr-07 | wow that event looks huge. you must have had some killer competition. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 131 Registered: Sep-09 | what do you mean im next |
Gold Member Username: JtownTexas Post Number: 3955 Registered: Mar-07 | you also got a sheit number for all the money and time you WASTED. whatever helps you sleep at night, that last comment tells me that you didn't bother to get projectors. Hopefully you won't blind anyone driving the opposite direction of you and cause them to wreck their vehicle. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 132 Registered: Sep-09 | i havent wasted any money or time.. do you know what my system is and what i got it for?? and i am extremely happy with the way everything sounds regarding my setup. im not trying to get big numbers.. |
Gold Member Username: JtownTexas Post Number: 3956 Registered: Mar-07 | Are you dumbassBLK? |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1875 Registered: Aug-07 | ![]() alama gates handing me my trophy... |
Gold Member Username: TejcurrentPost Number: 1986 Registered: Apr-07 | D- you're my hero. Sorry to thread jack, but I'm seriously considering getting a HID kit for my Tahoe, can anyone point me in the direction of everything I need and good brands? Everything is stock at the moment and I've never done any upgrades like this before. I do a lot of driving in the middle of nowhere and it's very difficult to see with stock lights. I would prefer as little color as possible - just white or a hint of blue. Thanks guys. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7412 Registered: Nov-05 | best thing to do is a retrofit.. and it can get pricey.. but well worth it.. oem quality > aftermarket |
Diamond Member Username: BestmankindPost Number: 23534 Registered: Oct-05 | s2k projectors for retrofit ftw. razor cut offs. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7413 Registered: Nov-05 | tsx and tl projectors are also nice.. or do a bi-xenon with some fx35s.. you can always color mod by spacing the lens.. or modding the cutoff |
Gold Member Username: TejcurrentPost Number: 1987 Registered: Apr-07 | Any links? I would like to do it nice, but I would like to keep it on a bit of a budget. I will wait to do it right if need be, but I don't know where to start. Like for instance, I've been searching retro fitting, but I'm having trouble finding information that is clear/concise. Thanks again. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2155 Registered: Jun-07 | i got mine from ddmtuning.com works great for me, and good price |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7414 Registered: Nov-05 | ddm makes cheap kits.. had group buys on the lgt boards.. a lot of people have issues with the kits.. ballasts always going out i have a ddm 3k for fogs.. no issues but i have a separate wiring harness and relay troy.. best thing is to check forums for your car and see if anyone offers it you can do it yourself.. buy a set of projector headlights and swap out projectors.. or mod your stock lights (if they have cleared lenses) to do so you'd need to read up on some builds.. you can do it many ways i did a retro on my oem projectors with fx35 projectors.. its on my cardomain - http://www.cardomain.com/ride/3108799 |
Gold Member Username: Livin_loudCOD4 Addict Post Number: 2954 Registered: Jan-06 | http://store.theretrofitsource.com/ |
