Fiat Scudo Clarion Radio CD Code
Username: Scotsgit
Can anyone help with a code for the following
Model PU-2294A©
SN CL040150977259C
Do I need anymore info
Thanks
Username: Regrooster
Post Number: 2134
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
