Silver Member Username: FrobiPost Number: 441 Registered: Aug-06 | On 118? |
Silver Member Username: SakapfetPost Number: 209 Registered: May-06 | my on 119,110 |
Gold Member Username: Mrskullz1New York Post Number: 1270 Registered: Feb-07 | yes the server is currently being worked on. Should be back up later today |
Bronze Member Username: MinetcalinPost Number: 54 Registered: Sep-07 | yep down .. should have checked here before unpligging,pluging , checking print server .... dvd time |
Silver Member Username: WabashSanto DomingoDominican Re... Post Number: 126 Registered: Oct-06 | Nfusion seems to be up. How come I can't connect to the server for software check and update? |
New member Username: BillhiggsPost Number: 1 Registered: Oct-09 | I havent been able to either for a while now |
Gold Member Username: GregrafPost Number: 3775 Registered: Dec-07 | The update server has been down for a few weeks now! That's why the "can not connect" screen appears,, it's not just you! You need the 1.53.1 latest Bin at the time actually! It's the latest one! Load using the web loader or Channel editor or Db9 Serial and 131 up loader s/w! |
New member Username: BillhiggsPost Number: 3 Registered: Oct-09 | any idea when it will be back up? Thanks |
Gold Member Username: GregrafPost Number: 3776 Registered: Dec-07 | Good question B higgs. Any idea when my PPV's will be back up? |
New member Username: BillhiggsPost Number: 4 Registered: Oct-09 | I am just happy to have most of the channels and the VOD's |
Gold Member Username: GregrafPost Number: 3777 Registered: Dec-07 | and the VOD's ?? |
New member Username: BillhiggsPost Number: 5 Registered: Oct-09 | the video on demands 5816 thru 5825 |
Bronze Member Username: ShacckPost Number: 31 Registered: Aug-06 | i sure dont have them! How did you get them? |
New member Username: BillhiggsPost Number: 6 Registered: Oct-09 | I stand corrected, i did have them, but I dont know. Guess i havent checked in a while, I am not much of a tv person. Sorry about the misinfo. |
New member Username: BillhiggsPost Number: 7 Registered: Oct-09 | heres kinda an interesting find, not sure how accurate it is tho. |
Gold Member Username: GregrafPost Number: 3779 Registered: Dec-07 | This one is updated daily. http://spreadsheets.google.com/pub?key=to8OFgfam7eXbwTGo2VkyXg&output=html |
Gold Member Username: GregrafPost Number: 3780 Registered: Dec-07 | https://www.ecoustics.com/electronics/forum/home-video/592865.html |
