New member Username: MsandsteadColorado Springs, Colorado Post Number: 2 Registered: Oct-09 | I had a friend install my two Alpine type R subs a while ago. but now I want to upgrade my system and get a better amp and deck. However, the two subs are slightly different and I dont know how to tell what theyre specs are. They are both 12" Type R's but one has a smooth rubber edge while the other has a few ridges around the edge. I bought them at different times from Ebay so I no longer have the boxes either. I'm not sure if anyone knows the difference, but I would appreciate any help. thanks |
Silver Member Username: DangerangerFredericktown, Ohio United States Post Number: 151 Registered: Mar-09 | have you checked out alpines website? |
New member Username: MsandsteadColorado Springs, Colorado Post Number: 3 Registered: Oct-09 | I have, and they are not providing any help in distinguishing the two subs... I really dont want to have to tear apart my box to check the back of the subs, but no one seems to know how to tell the difference otherwise. |
Silver Member Username: DangerangerFredericktown, Ohio United States Post Number: 152 Registered: Mar-09 | older - http://www.sonicelectronix.com/item_47_Alpine+SWR-1221D+Type+R+DVC+2-Ohm+12-.htm l newer- http://www.sonicelectronix.com/item_4243_Alpine+SWR-1222D+-TYPE+R-.html are those the 2 you are working with? |
New member Username: MsandsteadColorado Springs, Colorado Post Number: 4 Registered: Oct-09 | Oh yeah, those are the two different types. Ive been looking all over for that! I have them in the same sealed box which was wired to an Alpine amp by a friend of mine. It's time for a new amp and deck because I know the current amp isnt all too powerful and honestly I'm not even sure it was designed to support two subs. So if you have any suggestions to what amps I should look at, I'd really appreciate it! |
Silver Member Username: EricmbWaycross, Georgia United States Post Number: 226 Registered: Nov-08 | i'd get 2 matching subs first with the same rms wattage. |
New member Username: MsandsteadColorado Springs, Colorado Post Number: 5 Registered: Oct-09 | Ok not a problem. Ill plan on getting a matching SWR-1222D since the other one is discountinued. what would be a good amp for a pair of those? |
Silver Member Username: DangerangerFredericktown, Ohio United States Post Number: 153 Registered: Mar-09 | aq1200 www.audioque.com |
Silver Member Username: DangerangerFredericktown, Ohio United States Post Number: 154 Registered: Mar-09 | wait are they d2s or d4s? |
New member Username: MsandsteadColorado Springs, Colorado Post Number: 6 Registered: Oct-09 | I believe they are d4's |
New member Username: MsandsteadColorado Springs, Colorado Post Number: 7 Registered: Oct-09 | I believe they are 4D's |
