Bronze Member Username: 813thumperTampa, FL United States Post Number: 99 Registered: Sep-09 | My Gmax 1200 watt amplifier from JL audio. Looking for about 300 shipped. If you're interested let me know. Only been used for like 3 months, not pushed very hard. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 102 Registered: Sep-09 | is anyone interested.. no comments? |
Gold Member Username: Snowball123West Allis, WI Post Number: 3242 Registered: Oct-07 | not really. doesn't seem like a good deal at all. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 104 Registered: Sep-09 | 250? |
Gold Member Username: Snowball123West Allis, WI Post Number: 3244 Registered: Oct-07 | I've never even heard of the amp. And RD and Audioque can be had with the same power brand new for that price. Not trying o be a d*ck, but come on. |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 4037 Registered: May-07 | D@mn snow.... It IS JL Audio... Arn't they the best?!? lol i haven't heard of that line either. but I quit keepimg up with JL for the most part. GLWS |
Silver Member Username: 813thumperTampa, FL United States Post Number: 105 Registered: Sep-09 | i need to sell this amp! if you know anyone that will buy it let me know plz. its a great amp its from the G series line. im trying to sell it so i can get the ARC ks 1000.1!! |
Gold Member Username: Philly306If youre going to give... Post Number: 1454 Registered: Apr-07 | why? both those amps do pretty much the same thing. you are not going to hear a diffference between the two. |
Gold Member Username: Snowball123West Allis, WI Post Number: 3245 Registered: Oct-07 | well I'm not really going to suggest my friends getting ripped off for a 1200 watt amp. lol. I'd suggest just trying to get rid of it locally. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 106 Registered: Sep-09 | phil, my car only produces about 12V when everything is running so it only produces about 900 rms and it drops below that when all the accesories in my car are on. with the arc (from what ive heard) has something like the RIPS that JL has and if it does more power than what it is rated at then I will be getting more power. And it will send out a much cleaner signal to the subs. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12649 Registered: Jun-04 | Just to give you a comparison im selling a mtx 81000d rated at 2 ohms to produce 1500 watts for 200 plus shipping |
Gold Member Username: Philly306If youre going to give... Post Number: 1455 Registered: Apr-07 | So the solution to you voltage problem is to buy a new amp? wrong. either way if the gain is set properly the signal won't be any "cleaner" and you wont here a difference in the power. fix your car. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12651 Registered: Jun-04 | x2 |
Gold Member Username: Snowball123West Allis, WI Post Number: 3250 Registered: Oct-07 | you you think you'll hear a difference in 100 watts? there going to be no audible difference. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2893 Registered: May-04 | Try selling it on CA.com |
Silver Member Username: 813thumperTampa, FL United States Post Number: 107 Registered: Sep-09 | thats not the solution to my voltage problem, i know. i plan on doing big 3 and a second battery (possibly a bigger alternator in the future), but the technology in the ARC amp allows it to run at the same rms at a lower voltage level. and if ARC rates their amps like anyone else, then theres probably 200 watts hiding behind the label so that would be a difference of 300 watts or am i missing something? I am open to any and all suggestions, maybe another amp that would pair nicely with 2 13w3's? Maybe ill do the world a favor and keep my amp?? lol |
Gold Member Username: Philly306If youre going to give... Post Number: 1456 Registered: Apr-07 | in the end you will have pretty much the same output from both. You won't be able to tell a difference between the two. It sounds like you're just wanting to buy a new amp and you''re trying to justify it here. If you want to go ahead its your money to waste, excuse us for trying to help you. |
Silver Member Username: 813thumperTampa, FL United States Post Number: 109 Registered: Sep-09 | im not trying to justify it, i am seeing what different people have to say. a local stereo shop owner in my area says that the ARC is going to be a better amp than the one i have now and i was just trying to take his position so i could get a better idea of the opposing side. so thank you phil! i got what i wanted. im gonna keep my amp. not for sale. |
Gold Member Username: Snowball123West Allis, WI Post Number: 3252 Registered: Oct-07 | to. bad. you had a bunch of interest for it too.. |
