Choosing new speaker help
Username: Unreal_t
United States
Post Number: 93
Can anyone recommend some really good speakers for 2 channel stereo music only? I am currently running a harman kardon hk3480 and a set of polk rti8's and find them too bright and fatiguing. Yes I know a lot of you will say polk is trash but.... I read a lot of reviews about the lsi series.
Would the polk lsi series be the best choice? If not, i would appreciate some other recommendations . I want a set of warm sounding speakers I can listen to for long periods of time without fatigue to my ears. Budget is 1,000 dollars. Might go a bit higher...
Username: Exerciseguy
Fort Hamilton, NY United States
Post Number: 3062
I own an HK3485 and consider it fairly uncolored, so I don't think it's your amp; what is your source?
The Paradigm Studio 20v.5 & Monitor Audio GS10 would be on my short list in the slightly more than $1K category, and there are several others on the other side of $1K that are well worth considering, the Wharfedale EV02 & Diamond 10 (and 9) series are great options, as are the Monitor Audio RX (and RS) series, and the B&W 6-series.
But the Swan D2.1SE are particularly attractive and might represent the best deal going in the sub-$1K category from what I can tell, but I haven't heard them...yet.
http://www.theaudioinsider.com/product_info.php?products_id=69
http://www.enjoythemusic.com/magazine/equipment/0708/swans_d21se.htm
http://www.audioasylum.com/audio/speakers/messages/27/275456.html
But this is about you, what have you listened to?
