Craigslist is riddled with these ppl. "Wanna split the prize?" Is anyone REALLY that dumb? If you don't know what it's worth then you're not paying attention anyway. If someone is desperate for a certain piece don't you think common sense would tell you to investigate its' worth? You have better luck sifting through Mcdonald's trash than getting it from an actual person.
It's like holding a couple of dead lottery tickets and offering them to someone who has the winning powerball ticket so they can split the winnings. The game ends soon so there are millions scrambling to find the golden goose. Does anyone really comprehend the odds of 1 in half a billion? It's like getting bitten by a shark while getting hit by lightening, simultaneously, in the desert.
For amusement I reply to the ads. I tell them they can just have it. Then I tell them my son accidentally threw it away when they ask for my address. I'm a stinker.
Chances are an employee takes it and passes it off to a friend of a friend of a friend who eventually cashes in as a winner and its all split across a huge scheme.
