Username: Ytofmaisyachev BrrrrrrrrrSiberia
Post Number: 2 Registered: Oct-09
Tuesday, October 27, 2009 - 21:59 GMT I just got a Nfusion hd.I install the latests bin V1.3sr 25F via the uploader 1.7 using a serial cable. I did a scan of 110 & 119/118.8 + 91 & 82 and nothing is on right now. Did I did wrong somewhere,mist something in the install process ??? somebody ?? HELP MY OUT!! THANKS
Username: Dibblydooda Post Number: 13 Registered: Oct-09
Tuesday, October 27, 2009 - 22:32 GMT I don't know too much about Nfusion, but are you sure your dish is pointed at the correct sat when running your scans? Did you have another receiver before Nfusion that picked up the sats?
Username: Plymouth Canada
Post Number: 11448 Registered: Jan-08
Tuesday, October 27, 2009 - 22:46 GMT Ytofmaisyachev After loading a bin you must do a factory default then scan your satellites to assigned each channels to a server adress. In French: AprAs que tu as mis la bin tu dois faire un factory default puis scanne les satellites pour assigner les cannals au adresses des servers. Si tu as des problAmes ne te gAne pas, demande!
Post Number: 3 Registered: Oct-09
Tuesday, October 27, 2009 - 22:47 GMT All the sats gives me strong signal (85 & up ) except for 118.8 (around 50 percent),I was using a extremeview box before n3 came.
Post Number: 4 Registered: Oct-09
Tuesday, October 27, 2009 - 22:53 GMT Thanks plymouth for the advice.I'll give a try right now Merci Plymouth pour ton conseil. Je vais l'essayer de tout de suite.
Post Number: 11450 Registered: Jan-08
Tuesday, October 27, 2009 - 23:03 GMT Ytofmaisyachev Bienvenue! Yé ben drole ton nick!
