New member Username: VegassoundjunkieLas Vegas, Nevada United States Post Number: 1 Registered: Oct-09 | I want to build a downfire box for my JL 12w6v2. Going to do a vented enclosure and got the demensions for a vented box from JL. My question is, I want to change the demensions of the box (keeping the same cu.ft.) but then I would have to change the lengths of the slot port pieces (again keeping the same overall length width and height of the slot port). Hope that makes sense, is this ok to do or will it change the tuning? |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2781 Registered: May-07 | Should be the same, atleast to the ear. Not sure on how downfiring would affect it though. |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15555 Registered: Jul-05 | use this to reshape ur box ... http://www.reaudio.com/speaker_box/LPort_Box_Calc.html |
New member Username: VegassoundjunkieLas Vegas, Nevada United States Post Number: 2 Registered: Oct-09 | Thanks guys, I might actually be leaning more towards a sealed box now. going into a chevy s10 extended cab, I was told downfire was the way to go for this app. What are your opinions, sealed, ported, downfire etc.? Thanks again |
Silver Member Username: Simple_smithLapeer, Michigan United States Post Number: 118 Registered: Dec-08 | Personally, i would do a downfired ported enclosure since you have a good amount of room with the extended cab. So i kinda have a similar question. I'm making a center console box for my 92 sonoma standard cab and i am planning for the port to be along the back of the cab, but its gunna have to be a triangle port. Are there any different ways to figure this than finding the port area of the triangle port, then using and equivilant rectangle port to find the correct port length? |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2134 Registered: Jun-07 | ported down fire or make a port dumping out to the side |
