Silver Member Username: BoomtankRochester, NY USA Post Number: 647 Registered: Oct-06 | Got my new Irragi 380 amp HO alt today. Beast is heavy. Ill have some installed pix up later today. Its for my 03' Chevy Tahoe. ![]() ![]() |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12661 Registered: Jun-04 | monster alt. Irragi got a bad wrap but i got my 240 amp from him and had no problems |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15569 Registered: Jul-05 | 380A u say - wtf , thats alot of power ! ... |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 820 Registered: Nov-07 | Iraggi...and 380A in the same sentence.......uh oh......... Good luck... |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1825 Registered: Aug-07 | go test it, maybe you'll get 250 outta it :laughs: im curious to see if he still uses the parts from his local junk yard to build his brand new alts...and he better have a "beasty" stator and not the stock one in there |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9422 Registered: Jul-06 | I'm curious to see if it will even fit into the vehicle it's "made for". |
Silver Member Username: BoomtankRochester, NY USA Post Number: 648 Registered: Oct-06 | It fits in perfectly, but has very low idle amperage. Dom is replacing it with the 260amp amputator which should have better idle amps. (150 at 600 rpms ) |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1830 Registered: Aug-07 | ask dom where my money is that he owe's me while your at it....1000 dollars....court appointed.... |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9428 Registered: Jul-06 | Rofl, that sucks. You could ask Dom if he made my alternator bracket yet as well. |
Silver Member Username: BoomtankRochester, NY USA Post Number: 649 Registered: Oct-06 | wow, where do you guys get ho alts at if iraggi is unreliable? I thought he was the guy to go to for this stuff. |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1832 Registered: Aug-07 | mechman (my choice) or Dc power(another great source) |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 821 Registered: Nov-07 | ^This. Iraggi's been unreliable for years ![]() |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15575 Registered: Jul-05 | i didnt know a 380A existed since the highest i have seen is 300 but i know these ppl http://www.powermastermotorsports.com/spl_alternators.html have a 350 which they say is NOT for daily use """PLEASE NOTE: SPL alternators are for competition use only and are NOT intended for street driven vehicles.""" so does anybody really make a daily 380A ??? .... ![]() |
Gold Member Username: TejcurrentPost Number: 1961 Registered: Apr-07 | DC Power really makes one. I had a 380 tested - it did like 10a at idle and 280 peak. So basically 100amps less than rated, but you better not want to run a/c and stop at a red light. |
Gold Member Username: TejcurrentPost Number: 1962 Registered: Apr-07 | I will never go with Iraggi again, I feel like he owes me twice that D-$. He's been trying to clean up his bad c/s rep lately on the SMD forum, but he's just raising his post count, not doing anything to resolve past issues. He apologized to me for what happened, but that doesn't restore my faith or change the fact he screwed me over. |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1836 Registered: Aug-07 | well when you broke it down with normal shop charges and how many times to change it, not including the orginial cost of the alt it was around 3,000 in shop charges... i feel like making a thread "wheres my money you owe me appointed by court" or sumin like that |
