1/0 wire
Username: Kickerman
Post Number: 236
Does any1 kno about tsunami and monster cable wire. Open to all comments
Username: Exige
CDT, Audiopulse Dealer
Post Number: 814
For 1/0 wire, have a look at Shok Industries.
Username: Snowball123
West Allis, WI
Post Number: 3203
or a brand I always use.
Kicker Hyperflex.
But Shok wire is some solid stuff.
Username: Kickerman
Post Number: 237
i was asking because i knu right now but i need some more and i got a deal on some monster cable. i also found some tsunami for cheap too
Username: Kickerman
Post Number: 238
I checked out shok wiring and i like it. But he only has cca available. So my next question is that im looking to run about 5-7k. Would the cca be enough or do i neccesarily need 100% copper. Btw the cca is rated at 230A. I dont need the talk on electrical Upgrades because i have that already. It would be 2 runs of positive and 2 runs of negative. Can any1 help out??
West Allis, WI
Post Number: 3204
Yeah I'd prolly go 2 or maybe even 3 runs of each.
Username: Kickerman
Post Number: 239
So should the cca be enough or do i need te 100% copper
Username: Basebalz13
Moneta, Va Usa
Post Number: 1814
if your talking wire runs from the front to the back? i would do 2 runs as that woull carry roughly 400 amps. and i doubt you have more than a 400 amp alternator :D
and no you dont have to get the 100% copper version, however if your willing to wait a little while the competition series will be in stock and you can have some of the greatest wire and the greatest price ;)
Username: Kickerman
Post Number: 240
He wont have the other wire in stock until next year
