Well. 1st thoughts....(Pics)
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3920
This came in today... It is my New 270 amp DC Power Alt (200 amp at idle). I got it to replace the constantly failing Mechman hunk o junk.
Right off the bat I notice this thing weighs at least 10#'s heavier. Robbie went 50/50 with me to get it to me overnight from California. He did not have to do that so it is much appreicated. It does look a little more complicated of an install due to a lot more detailed wiring harness that came with it, without instructions .... I'm sure that he will let me know what goes where with a phone call.. I paid an extra $50 for the internally regulated model which guarntees my voltage will charge to the 14.9-15.1v range. And unlike Mechmans warnings about not putting it to heavy use for over 10 mins at a time (or a song or two), he promised that I can put as much drainage load for as long as I could handle it on this alt, without any issues.. That being said I do not intend to abuse this alt. I just expect it to handle any normal useage w/o failure.... Mechman DID NOT by any means.. I will give more reviews after installation.. Also added 3 C+D Tech Batts in place of the SVR's I was running... Big difference even with factory alt... Never dropped below 11.5 no matter how long I kept the bass pumpin'.. Keep in mind that the 132 amp factory alt only charges to 13.1 v at the most. and is regulated by thePCM... Terrible Design flaw.Upload
Username: Snowball123
West Allis, WI
Post Number: 3137
Nice Mark! I was thinking about getting a DC Power after I couldn't figure out the Mechman alt, but all is good now and I love the alt. Put that ish in.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1753
i thought it was just your vehicle mark?
Username: Hittin1
Post Number: 3925
huh?
I know of 3 people who dropped Mechman due to multiple failures of their equipment.. If a drive from Lake Charles to Lafayette (~80 miles) with radio and amps completely unhooked (i never play anything through the subs the day of a competition) is too hard on a $500+ alternator and it overheats (for the 3rd time).... I don't think it's worth its weight in dog shiit... It worked great when it was functioning.. Had I known from the get-go that he is beefing up a ford 4G alternator, I would have passed to begin with.
Username: Hittin1
Post Number: 3926
Again, I will not say anything bad about Mechman as far as customer service and communication.. When I sent my alt to them it was repaired and shipped the same day all 5 times (except the last time in which it was repaired and never shipped and eventually disappeared- he was truthful about the situation and sent me a brand new one and told me that this was the last he would repair under warantee. I sold the new one as new and got the Alt that I should have gotten to begin with)
Username: Hdubb
Team Revolution
Post Number: 4229
hmm ive never had a problem with my mechman alty. but the dc looks very good. you get a good price?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10684
Now that looks like a beefy alternator....
But I am interested to know why you would pay extra to get a internal regulator model..... external regulators are usually considered the superior design as they are adjustable.
Username: Hittin1
Post Number: 3929
I paidextra for the internal regulator as opposed to the Jeep factory setup. Which would not have a regulator at all. The Voltage is controlled by the PCM as I stated in the last sentence of my first post. I could have paid even more for the external regulator, but I don't forsee running a multiple alt setup. I haven't found any dual alt brackets and would probably have to make my own... This is one reason that I am considering changing to a Chevy SUV.
Hunter, I paid the same price I paid for my Mechman. Well that was before the $50 upgrade. He gave me $100 off the original price.
West Allis, WI
Post Number: 3141
yeah but Hunter prolly paid a hell of a lot cheaper than you because he' on the team.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10687
I c. But even with one alternator the external regulator allows you to manually set voltage.
Moneta, Va Usa
Post Number: 1766
lol team prices are very nice :-)
and yeh just cause you get a external regulator doesnt mean its for dual alt setups. because actually the standard blue case ext volt reg used by most of the companies carrues a 15 amp dray. my MECHMAN alt rotar is 7.5 or 8 amp's(cant remember at this second) so either way i wouldnt be able to control two alts with one regulator. you would be over doing the regulator...now if the DC rotator is as beefy as it should be(which im not doubting) then you would run into the same problem :-)
but the plus of having the volt regulator is u can pull into the lane...set ur idle up to 2000rpms' THEN turn ur voltage up to say 15.3-15.4 and make ur burp. turn the reg back down to id say around 14.0-14.4.
the reason being for that is because the big batteries like the D3100 or 2400 etc require a 15-20 amp to maintain a 15.0 charge. so say you got 5 of the big batts theres a 100 amp draw already just to keep them charged at 15.0 then you have your system playing, car running, and any other accs.
now at 14.0-14.4 it only draws roughly 5 amps per big batt. and well i guess you get my point from there :-)
Username: Hittin1
Post Number: 3935
I know that Dual Alts is not the only reason to have an external regulator. But that would be my use for it to run a 16v+ setup daily.. I
I got the install done and the alt does what it is supposed to do. 14.9-15.0v
13.5 is about as low as the voltage drops when I have the volume turned up. Pain in the @ss to install, but worth it so far.
Moneta, Va Usa
Post Number: 1776
ohh i see...heres a trick for ya, but only works in the lanes
so you have your stock wire going from the alt. to the battery, then to the truck right?
then you have your 1/0 going from your alt to your battery then to the rest.
well you run your 1/0 wire from the alt str8t to your battery bank. but also have a 1/0 going from alt to your front battery. when you pull into the lane you unhook the wire going from your alt to your front battery. then turn up your voltage. this away your truck is running off your front battery for a 30 secs to a minute. no harm done. and then u can run a 16v setup and still be daily(just gotta have two battery banks i reckon?)
Username: Hittin1
Post Number: 3936
be easier to just burp on a fresh charged bank of 16v batts... not even hooked to alt.
Username: Insearchofbass
York, Pennsylvania
Post Number: 12323
Nice alt there Mark. A lot of beef.
Username: Hittin1
Post Number: 3972
seen it as high as 15.7v
West Allis, WI
Post Number: 3182
that can't be good for the car's accessories.
Username: Hittin1
Post Number: 3976
no problems.......yet
Username: Mpinto19k
Colorado Springs/, CO
Post Number: 300
Well I sure as sh!t hope my 4G doesn't have the same problems!
Username: Hittin1
Post Number: 3977
good luck... this has givin me zero problems as of yet.. thankjfully... Plus i'm not worried about how long i keep the volume cranked like I was with the Mechman alt.
Username: Mpinto19k
Post Number: 301
Man I sure hope I dont have that problem! Weird but my stock alt doesn't have problems right now either so idk I'm super curious
Username: Louisiana_crx
North, Louisiana USA
nice What vehicle is that going in? I need to update a couple of alternators myself....and was curious to which company to go with
i can tell by the dash kit its a Dodge vehicle ..one in need is my Wrangler so maybe there's hope
Username: Hittin1
Post Number: 4003
DCPOWERINC.COM
This went into my '99 JGC Laredo 4.0L..
What year is your Wrangler? What Engine?
Moneta, Va Usa
Post Number: 1813
depending on how many cpu controlled equipment in your vehicle you could charge your stuff at 16 volts and be fine, in a CRX you could even charge 16.5 and be fine :D
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 3179
Looks legit, Mark. Hopefully you don't get broken down again at another show lol.
A typical stock alternator charges at 15 volts when it's cold.
West Allis, WI
Post Number: 3196
ok all knowing pizza pimp.
Username: Tatonka
Post Number: 3180
I have meaty powers, I'm supposed to know this stuff.
Username: Cdb004
I got 6 12s 153.1 daily
Post Number: 113
Super feg powers maybe!
