Upgrading my sounds on my new ride
Username: Janmeg23
hello guys. im a newbie on mobile sound and i need your suggestions. ill be getting a new car as a christmas present from mom my (but i dont know what brand and model she would be giving me) and planned to give it a sound upgrade firstly. i want a sql set up. i dont know what sub to use but a friend of mine suggested the re xxx6.5 component set for my speakers but suggestions are open though coz i want a good sql system for my car and my budget is open. TIA
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15541
it will be difficult to answer that since nobody cud rec something when they dont know what vehicle the equipment will be going into
u have to look at available speaker depth in the doors & if ur going to put a sub how much space is there etc
get ur ride 1st then ppl can help u better
also u must set a fixed but slightly adjustable realistic budget since speakers & amps can cost $50-$5000...
Username: Janmeg23
i guess it would be a toyota prado.. maybe i could spend up to $6000 for my budget..
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3998
with that budget, you will have a lot of choices. I'll chime in later.
Username: Turnmat
Www.j-designs.org
Post Number: 1232
1 high output alt 240-300 amp
1-2 Kinetik 2000
1 dd 9518z
1 sundown saz2000d or a saz3500d
Username: Janmeg23
i would like to go for 4 pairs of speakers, 2 pairs on my front door and 2 at the back.. and 2 subs at my trunk..
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 933
1-2 Kinetik 2000
1 dd 9518z
X2 lol
Username: Janmeg23
@Quentin
what alternator would u recommend me to use? a link of it would be nice and how much would it cost? thanks
im planning to go with 2 750-1000 watt rms subs and for my speakers, 4 pairs ranging to 100-150 watt rms. TIA
