Username: Janmeg23 Post Number: 1 Registered: Oct-09
Saturday, October 10, 2009 - 15:52 GMT hello guys. im a newbie on mobile sound and i need your suggestions. ill be getting a new car as a christmas present from mom my (but i dont know what brand and model she would be giving me) and planned to give it a sound upgrade firstly. i want a sql set up. i dont know what sub to use but a friend of mine suggested the re xxx6.5 component set for my speakers but suggestions are open though coz i want a good sql system for my car and my budget is open. TIA
Username: Rovin 1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15541 Registered: Jul-05
Saturday, October 10, 2009 - 17:17 GMT it will be difficult to answer that since nobody cud rec something when they dont know what vehicle the equipment will be going into u have to look at available speaker depth in the doors & if ur going to put a sub how much space is there etc get ur ride 1st then ppl can help u better also u must set a fixed but slightly adjustable realistic budget since speakers & amps can cost $50-$5000...
Username: Janmeg23 Post Number: 2 Registered: Oct-09
Saturday, October 10, 2009 - 17:25 GMT i guess it would be a toyota prado.. maybe i could spend up to $6000 for my budget..
Username: Hittin1 TEAM REVOLUTION,
La.
Lake Charles...
Post Number: 3998 Registered: May-07
Saturday, October 10, 2009 - 20:30 GMT with that budget, you will have a lot of choices. I'll chime in later.
Username: Turnmat Www.j-designs.org
Post Number: 1232 Registered: Feb-07
Saturday, October 10, 2009 - 21:43 GMT 1 high output alt 240-300 amp 1-2 Kinetik 2000 1 dd 9518z 1 sundown saz2000d or a saz3500d
Username: Janmeg23 Post Number: 3 Registered: Oct-09
Sunday, October 11, 2009 - 02:27 GMT i would like to go for 4 pairs of speakers, 2 pairs on my front door and 2 at the back.. and 2 subs at my trunk..
Username: Kingandsons07 TEAM NEBRASKA
Lincoln,NE
Post Number: 933 Registered: Aug-08
Sunday, October 11, 2009 - 04:19 GMT 1 high output alt 240-300 amp 1-2 Kinetik 2000 1 dd 9518z 1 sundown saz2000d or a saz3500d X2 lol
Username: Janmeg23 Post Number: 4 Registered: Oct-09
Sunday, October 11, 2009 - 05:38 GMT @Quentin what alternator would u recommend me to use? a link of it would be nice and how much would it cost? thanks im planning to go with 2 750-1000 watt rms subs and for my speakers, 4 pairs ranging to 100-150 watt rms. TIA
