Username: Gcs8 Atlanta,
Ga
Post Number: 63 Registered: Sep-09
Thursday, October 08, 2009 - 04:16 GMT had two idea's i wanted to try. 1.) poly fill my dead space in the area between my trunk lid and the cover on the inside. 2.) porting my sealed boxes with 4 inch aero ports.
Username: Insearchofbass York,
Pennsylvania
Post Number: 12565 Registered: Jun-04
Thursday, October 08, 2009 - 14:56 GMT Porting a sealed box is a bad idea because sealed boxes are smaller than the recommended ported size usually.
Ga
Post Number: 64 Registered: Sep-09
Thursday, October 08, 2009 - 18:22 GMT it was a costume box to start with so i fingered it wouldn't mind to much.
