Bronze Member Username: Tekila2006Post Number: 85 Registered: Aug-07 | Hello I just threw away my VS in recycle bin and am ready to move on something else. I know there's a lot posts on Nfusion here and most of them are too advanced for me. I just have some basic questions, so can someone please provide me infos regarding Nfusion solaris? 1) is this good receiver for BEV? how about globecast? 2) does the connection require special IP, username and password like IKS on DVB? 3) What is the best website for Nfusion supports and channel list? Thanks Thanks guys. |
Silver Member Username: SumpPost Number: 699 Registered: Aug-09 | 1) yes 2) no just like hooking up computer on your network 3) no comment |
Gold Member Username: GregrafPost Number: 3551 Registered: Dec-07 | no comment |
Gold Member Username: GregrafPost Number: 3552 Registered: Dec-07 | http://spreadsheets.google.com/pub?key=to8OFgfam7eXbwTGo2VkyXg&output=html |
Platinum Member Username: PlymouthCanada Post Number: 11194 Registered: Jan-08 | tekila Nfusion work fine on Globecast like AMC4 and many other free to Air! Ecoustics is the best forum But this forum can help you: www.nfusionforum.com/ |
Gold Member Username: GregrafPost Number: 3555 Registered: Dec-07 | good info Plymouth |
Platinum Member Username: PlymouthCanada Post Number: 11195 Registered: Jan-08 | Thanks Greg! |
Bronze Member Username: Tekila2006Post Number: 86 Registered: Aug-07 | Thanks to all. Very helpful and fast info... I absolutely agree that Ecoustics is the best site as there's great people like you ready to help other, anytime for almost any thing. P.S. Plymouth, Pacquioa vs Cotto le mois prochain, rendez-vous a la Cage pour une bonne biere? . |
Gold Member Username: GregrafPost Number: 3560 Registered: Dec-07 | your welcome tekila we are always here to help |
Silver Member Username: ChumleyPost Number: 600 Registered: Dec-08 |
Platinum Member Username: PlymouthCanada Post Number: 11197 Registered: Jan-08 | tekila C'est une modite bonne idee!!!! |
Platinum Member Username: PlymouthCanada Post Number: 11198 Registered: Jan-08 | Cumley NFusion is not able to drive a Motorized dish because its power supply have only 400 mA and Usals doesn't work fine but if the dish is pointed on the satellite, it work fine. |
Silver Member Username: RtfPost Number: 116 Registered: Aug-07 | I would rather have the beer Plymouth |
Platinum Member Username: NydasPost Number: 16273 Registered: Jun-06 | Chumley aka justforhaha's aka LK has had difficulty in understanding the power supply limitations imposed by the power supply in a FTA receiver which is often less than the power supply of DN receivers. She had the same difficulty when I tried to explain to her 2-3 years ago, the limitations imposed by the power supply demand of Dish LNBs with DP34. Some people's minds are fossilised in the circumstances of 2004 and will never change and this particular person is a living but half dead example of insane stubbornness. |
Platinum Member Username: NydasPost Number: 16275 Registered: Jun-06 | "FTA receivers do not have enough power to power Dish LNBs AND a DP34" That's what I said and you disagreed to an extent that you tried to ridicule me out of this forum. "NFusion is not able to drive a Motorized dish because its power supply have only 400 mA and Usals doesn't work fine but if the dish is pointed on the satellite, it work fine." That's waht Plymouth said. Chumley aka LK: Did you try? Or were you trying to ridicule Plymouth because his posts initially appeared contradictory? LEARN, WOMAN, LEARN. All issues and people you don't like cannot be thrown out of this forum by profanity or ridicule or soliloquies based on 10 nicks. Go and take a dive in Largo Key |
Silver Member Username: SumpPost Number: 704 Registered: Aug-09 | I do not want to start a bashing thing .. would like to keep it "TECH" only .. from what i have learned .. 1) nfusion does run motorized dish 2) motorized dish using single NON DP Plus LNB is not problem 3) DP Plus LNB's have the 500ma+ threshold 4) DP 44 with power inserter solves the DPP LNB internal switch power issue |
Platinum Member Username: NydasPost Number: 16276 Registered: Jun-06 | Quite simply, Plymouth said that you can get a Dish on Nfusion if you are pointing to it, but you cannot get it to it using the motor of a motorised dish. I did not see any ambiguity in it. Sump: The issue of inadequacy of power supply in DP34s and therefore need to use DP44 or a power insertion was suggested by me 2-3 years ago and this person, Chumley at that time posting as the great genius LK and some of her cronies pounced upon me as if it was heresy. |
Silver Member Username: SumpPost Number: 705 Registered: Aug-09 | quote ... Quite simply, Plymouth said that you can get a Dish on Nfusion if you are pointing to it, but you cannot get it to it using the motor of a motorised dish. I did not see any ambiguity in it. Sump: The issue of inadequacy of power supply in DP34s and therefore need to use DP44 or a power insertion was suggested by me 2-3 years ago and this person, Chumley at that time posting as the great genius LK and some of her cronies pounced upon me as if it was heresy. Quote I guess here is my confusion .. It is in the term Dp 34 now i could be CORNfused about that term , I thought that that was a switch not an LNB ? |
Platinum Member Username: PlymouthCanada Post Number: 11199 Registered: Jan-08 | whiskey I have 2 HH-90 and it seems that the new SG-1200 doesn't have this problem. With the NFusion Solaris I must choose a Horizontal channel to make that it work, note I have same problem with the CW 600P. |
Platinum Member Username: NydasPost Number: 16279 Registered: Jun-06 | Sump: Now I have to say - where in your stupid head did you see that i said DP34 was a LNB? You were similarly confused in discussions about routers, and I NOTE THAT PEOPLE AT DSSROOKIE HAVE ALSO NOTED SERIOUS INCONSISTENCIES IN YOUR STATEMENTS. I know what i know and post about it. I don't post about things I do not know about, if at all I would qualify it with "I suspect" or "I am told" So Keep your CCNP to yourself. This is a NOT a CISCO forum. Beleive me, when I say that I can give you an eyefull of stuff on Unified communications, routers, etc, but I always remember that this is a satellite forum. So don't cross swords with me and reduce your pimping for kboxsales. |
Platinum Member Username: NydasPost Number: 16280 Registered: Jun-06 | "SG2100 self-powered satellite motor" I wonder what "self-powered" means. |
Platinum Member Username: NydasPost Number: 16281 Registered: Jun-06 | My understanding is and Plymouth may correct me if I am wrong, that sg2100 and similar motors have a maximum power draw of 350mA and therefore may be used with many FTAs, whereas some of the other motors with a heavier power dwaw would fail. |
Platinum Member Username: PlymouthCanada Post Number: 11200 Registered: Jan-08 | Nalin I will buy a new motor as soon as possible because I experiment many problem with those HH-90 which I think is not available now, The Viewsat Ultra work fine to drive the HH-90 with a line amplifier. As usual the bashers come perturbate a thread for any reason. The SG-1200 is powered by the receiver but is slower to tracked the satellites and is able to track more degrees than a HH-90 which can help me to get Europeen satellite. Viewsat Ultra: 500 ma NFusion Solaris: 400 ma Captiveworks 600P: Not Available |
Silver Member Username: SumpPost Number: 706 Registered: Aug-09 | Nalin, i did not try to offend, i only wanted clarification of what was said, The personal bashing has no place here nor does networking in this thread. It has simple question based on what what written that's all. |
Platinum Member Username: PlymouthCanada Post Number: 11201 Registered: Jan-08 | It could be funny to go take a good beer all friends and ennemy and discussed Satellites and talk of our differents! I know that it's only a dream but it could be funny! |
Silver Member Username: SumpPost Number: 707 Registered: Aug-09 | that would be good ! |
Bronze Member Username: Pirate_pete_209Post Number: 75 Registered: Jul-09 | Plymouth It could be funny to go take a good beer all friends and ennemy and discussed Satellites and talk of our differents! YES, it would be very funny like a blind date btw Plymouth you have no enemies they are all trying to help you. |
Platinum Member Username: PlymouthCanada Post Number: 11206 Registered: Jan-08 | Cptn The blind date is for g/a/y only which are not welcome! |
Platinum Member Username: NydasPost Number: 16282 Registered: Jun-06 | Chumley aka justforhaha's aka LK: YOU are the biggest idiot of this forum. I was talking about World Cup football, something you and a lot of people have interest in and YOU have been posting threads about football events. NFL Football Line https://www.ecoustics.com/electronics/forum/home-video/593631.html YOU, IDIOT, are responsible for countless posts about Sentanta Sports channel. I find a news item which says clearly that this paritcular FOOTBALL EVENT will not be televised and will be available on line only. You have weird sense of responsibility or concern for news relating to football when you start mocking me for that post. YOU DO NOT DESERVE TO BE ON THIS FORUM. |
Gold Member Username: GregrafPost Number: 3563 Registered: Dec-07 | Niether do you b1tch |
Platinum Member Username: NydasPost Number: 16285 Registered: Jun-06 | Greg Ruffian: Always there trying to protect LK, AND NEVER SUCCEEDING. If you are not careful, Plymouth might ban you. |
Platinum Member Username: PlymouthCanada Post Number: 11220 Registered: Jan-08 | Nalin Gregraf Nalin you point LK each times that Chumley or any others come bashed a members, I can tell that LK is for nothing but LK friends and LK ennemy come bashed here. On the other side Gregraf is on you and I know it's not very funny! I know that you and Gregraf are not friends but to keep it fairplay for both you, I will never ban you or Gregraf for this reason. LK is everytimes a good reason for many members to keep the war between them. Both try to keep peace between you, but I admit that sometimes it make me laught and it give a special shape to Ecoustics where you can found it on others sites. So it's very difficult to mod in this condition. |
Silver Member Username: El_toro_the_greatNC USA Post Number: 132 Registered: Jul-09 | What I would like to know who is the mo and who is the mod or the azzhole? King Tapeman Nalin Nyda Gregfag Plymouth Chumley's and Whiskey's posts were deleted on this thread for no reason if Iam wrong then put the posts back up. A public forum open to the public and to their members have a right to know. They were only correcting Nalin Nyda and Plymouth that had posted the wrong info. Nalin Nyda and Plymouth started bashing Chumley and saying that Chumley is LK which I have proof that he is not LK. Whiskey's and Chumley's posts were deleted There were no rules broken Nalin Nyda and Plymouth broken the rules, but their posts are still here. If I am wrong I will close my account. Thanks to ecoustic's Archives their posts can prove what i am saying is the truth and nothing but the truth.I can post alot of Senior Member's names that have left here on account of these Jerks and when I say Jerks I am trying to be nice to them because I am a nice guy. |
Platinum Member Username: NydasPost Number: 16294 Registered: Jun-06 | You are wrong, so you should close your account. |
Bronze Member Username: Blade1Post Number: 39 Registered: Jul-09 | Whiskey is g@y what can I say? He was born that way |
Platinum Member Username: PlymouthCanada Post Number: 11226 Registered: Jan-08 | El Toro Nalin s right! You are wrong, so you should close your account. Whiskey and Chumley start bashed first, like LK and many others. All post from those guys are stupid and are deleted for this reason. |
Silver Member Username: El_toro_the_greatNC USA Post Number: 133 Registered: Jul-09 | Show proof you lying saw off B!tch You and that old sandniger will bring this forum down.Do you hear me now. Plymouth Platinum Member Username: Plymouth Canada Post Number: 11198 Registered: Jan-08 Posted on Monday, October 05, 2009 - 07:10 am: -------------------------------------------------------------------------------- Cumley NFusion is not able to drive a Motorized dish because its power supply have only 400 mA and Usals doesn't work fine but if the dish is pointed on the satellite, it work fine. sump Silver Member Username: Sump Post Number: 704 Registered: Aug-09 Posted on Monday, October 05, 2009 - 12:39 pm: -------------------------------------------------------------------------------- I do not want to start a bashing thing .. would like to keep it "TECH" only .. from what i have learned .. 1) nfusion does run motorized dish 2) motorized dish using single NON DP Plus LNB is not problem 3) DP Plus LNB's have the 500ma+ threshold 4) DP 44 with power inserter solves the DPP LNB internal switch power issue Whiskey and Chumley start bashed first, like LK and many others. Show proof you saw off B!tch |
Platinum Member Username: PlymouthCanada Post Number: 11228 Registered: Jan-08 | One more stupid post! |
Silver Member Username: El_toro_the_greatNC USA Post Number: 135 Registered: Jul-09 | I agree you post false info.sump, Chumley and Whiskey corrects you and now you call it a stupid post. You are really fu-ckup. |
Silver Member Username: El_tora_the_greatPost Number: 142 Registered: Sep-09 | Whiskey you are wrong and It makes me sad to call you bro. Nalin Nyda Is the mole. Plymouth Is a stupid frenchfry King Tapeman Is a genious and Gregraf has always bin a friend of LKs. If you read "any" of the archives you would know at least that. You had better close your account as I am taking over now. Most of the time I delete my own posts.which by the way I have more than u. |
Silver Member Username: PicanhaEast LA Post Number: 754 Registered: Jun-08 | Kick Nalie's asz wiskey |
Silver Member Username: ChumleyPost Number: 604 Registered: Dec-08 |
New member Username: Zhetti4mePost Number: 7 Registered: Apr-09 | Maybe solaris nfusion will run a motor. xxxx:// |
Platinum Member Username: PlymouthCanada Post Number: 11230 Registered: Jan-08 | Pat Yes the Solaris can run a motor but the Viewsat is much better for it and Free to Air with many settings like motor positioning on live channel. Many time the Solaris lose the satellite then return to reference point. With a long cable, a signal Booster and a motor, you will lose few volts need to turn the dish. But like I says on post above this problem is not on SG-1200 |
Silver Member Username: ChumleyPost Number: 606 Registered: Dec-08 | |
Silver Member Username: PicanhaEast LA Post Number: 755 Registered: Jun-08 | |
Bronze Member Username: Sat22Post Number: 28 Registered: Sep-08 | Hi guys, No hope for a VS fix so I'm considering the Solaris but I need some feedback. 1) What channels don't work ? Are all pay-per-views blocked ? What about Bell VOD ? 2) Downtime/ECM ? How often and how quickly does it comes back ? 3) Cheapest price for wirelles kit (hopefully less than $89.99). I have both Bell & DN dishes on my roof. Tx. |
Gold Member Username: GregrafPost Number: 3567 Registered: Dec-07 | http://spreadsheets.google.com/pub?key=to8OFgfam7eXbwTGo2VkyXg&output=html |
Gold Member Username: GregrafPost Number: 3568 Registered: Dec-07 | Read this thread https://www.ecoustics.com/electronics/forum/home-video/592865.html |
Gold Member Username: GregrafPost Number: 3569 Registered: Dec-07 | No downtime very rare anyways. But go with the Phoenix its the more up to date one less likely to become a doorstop. |
Bronze Member Username: Sat22Post Number: 29 Registered: Sep-08 | Thanks Gregraf ! Does Nfusion support the N3 channels on Globecast as well ? |
