Hello. I'm not sure what happened, but now my car alarm is no longer working. The blue security led is constantly on whether the car is on or not. I can lock and unlock the car with the transmitter but i've tested the alarm by opening the door from the inside and it doesn't work. How can i fix this? Where can i find a code book? The manual doesn't tell you how to program it.
I figured it out. I somehow unknowingly disabled the alarm system by pressing a certain combination of buttons on the transmitter with the passenger door open.
I had to open the passenger door, press the lock button, press the aux button, and press the lock button again and now it is working perfectly again.
