Cable splitter
Username: Downre
i Got one of those splitters with 2 @ -7dbs & 1 with -3... Which one of those should i hook my modem connection into?
Thanks
This is what i get in the -3:
Signal Acquired at 459.000 MHz
SNR: 36.5 dB
Received Signal Strength: 10.6 dBmV
Bit Error Rate: 0.433 %
Modulation: 256 QAM
Frequency: 25.3 MHz
Power Level: 38.0 dBmV
Channel ID: 3
This is what i get in the -7:
Signal Acquired at 465.000 MHz
SNR: 37.3 dB
Received Signal Strength: 8.0 dBmV
Bit Error Rate: 0.000 %
Modulation: 256 QAM
Connection: Acquired
Frequency: 28.7 MHz
Power Level: 50.5 dBmV
Channel ID: 2
Modulation: 16 QAM
I was getting these alot in the -7:
Fri Mar 19 01:24:50 2010 Notice 6 TLV-11 - unrecognized OID
Fri Mar 19 01:24:47 2010 Critical 3 DHCP WARNING - Non-critical field invalid in response.
Fri Mar 19 01:24:44 2010 Critical 3 DHCP FAILED - Discover sent, no offer received
Fri Mar 19 01:24:35 2010 Critical 3 No Ranging Response received - T3 time-out
Fri Mar 19 01:23:48 2010 Critical 3 Received Response to Broadcast Maintenance Request, But no Un...
Fri Mar 19 01:23:16 2010 Critical 3 Started Unicast Maintenance Ranging - No Response received - ...
Fri Mar 19 00:07:04 2010 Notice 6 TLV-11 - unrecognized OID
Fri Mar 19 00:07:01 2010 Critical 3 DHCP WARNING - Non-critical field invalid in response.
Fri Mar 19 00:06:52 2010 Critical 3 No Ranging Response received - T3 time-out
Fri Mar 19 00:06:43 2010 Critical 3 Received Response to Broadcast Maintenance Request, But no Un...
Username: Ieee488
Post Number: 303
I'm not understanding what you bought.
People don't use cable "splitters" for Ethernet cabling. They use switches and hubs.
Username: Downre
its thatUpload
Username: Ieee488
Post Number: 304
You're going to hook up a dial-up modem to that????
I don't think so.
And you certainly can't hook up a DSL modem to that either.
Not sure where you are going with this....}
Username: Downre
its what my isp put in "professionally" It worked fine for 5 years
Username: Downre
Its a cable modem.
Username: Ieee488
Post Number: 305
You must get your internet over cable then.
The RF cable from Comcast or whoever is your cable company goes to your cable modem box that they would give you.
Your computer still connects via Ethernet cable.
Don't you also have a cable box for the TV?
That should probably be connected to the -3dB port.
You don't really have much choice unless you buy one of your own.
Username: Downre
Post Number: 7
Yeah, sorry for confusion, i dont know the terms...
My cable goes like this. From the wall, to that RF Splitter thing i posted a pic about above.. the -3db has a cable running from that to my cable modem, one of the -7db is going to my Cable tv box & the other is going to another cable tv box in a diffrent room.
Username: Ieee488
Post Number: 306
If it's worked in the post, I'd be contacting your cable company.
I thought you'd just putting this together.
Need to Register?
Forgot Password?
Enable HTML code in message
