Ported vs. sealed box
Username: 813thumper
Tampa, FL United States
Post Number: 66
I am trying to build a box for my brother for his Jetta and I'm not sure whether to go with ported or sealed enclosure. I know there is no right or wrong answer, but I don't have a car with a separate trunk. I have a Scion xB and I have heard what both sound like in my car (I prefer ported) but does it make a difference in a car with a sealed trunk?
Username: Dustin3
D&L Audio Tech.Dustin
Post Number: 5117
what driver is he using?
Username: Skdooley
Roanoke, VA Usa
In my experience with sealed trunks, as like the jetta, it actually helps the sound of the subs. The trunk is not completely shut off from the rest of the car, so the trunk itself acts kind of like a larger sealed enclosure around the subs and helps it to resonate throughout the car. A friend of mine has 2 kicker 12 L5's on a 1000 rms in a factory ported enclosure and they are super loud in his Jetta. It all comes down to what he is listening to and his prefrence. If he wants loud, go ported, if he wants better SQ go sealed.
Username: Johammbass
IRL
Post Number: 763
I prefer sealed, I think it's a bit more precise.
Post Number: 67
Its either gonna be a 10W1v2-4 or a 12W1v2-4. He's not looking for a whole lot of bass and I found an incredible deal on both of these subs used. So the consensus is sealed then?
Username: Skdooley
Roanoke, VA Usa
If you're not looking for a whole lot of bass then yes, sealed.
Username: The_image_dynamic
San Diego, California
Post Number: 5351
Shawn that is kind of a blanket statement there...
A fairly high output driver (Fi Q, RE SE, AP Revo, SS RL-S etc.) will hit hard and low in a properly built sealed box, and without any of the artifacts and peakiness (3dB at the port frequency alone) of ported boxes. And maybe more importantly, sealed boxes also avoid the issues of reproducing frequencies below the tuning point, and eliminate the associated damage risks that require subsonic filtering.
For me, and I have built a few boxes in my time, I go sealed unless I have a very good reason (or application) not to. Sealed boxes have a flat response, hit lower (but without the accentuated peak), are more accurate sounding, and have a tight clean sound.
Post Number: 69
ok thanks for the help guys! Ill try to post pictures once I get everything in.
Username: El_tora_the_great
Post Number: 122
Do you have a camera?
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 894
i have done nothing but ported and my next setup i'm planing to go sealed for all around SQ,
i may go ported if i don't like sealed, just have to wait and see
Post Number: 72
yes i have a camera but i probably wont be doing anything for a couple of weeks. this is my first build so im gonna take my time to do everything right.
