Car audio code for a clarion
Username: Avidgolfer
g'day ive been trying to get a code for the clarion model PS - 2367A-A... the only numbers on the stereo were 051722877 and on the back was
L30041219
can someone help me or do i have to see the dealer.
cheers
d
Username: Regrooster
Post Number: 1952
The only CLARION code that can be calculated for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
