Help please I trying to get chanel
Username: Born_hard
Post Number: 12
I'm trying to get Aghapy TV 11945 V tp 12 from galaxy 16 at 99.0°W
I did get chanel quality 45% screen is black no audio
is it because it is in PAL? reciever Omegasat DSB5700
I do blind scan, chanel comes no luck no A/V any help appreciated
Username: Sump
Post Number: 563
Quality does not sound high enough IMHO
Username: Tapeman
New York Citay in-HD, NY
Post Number: 4455
Is this the first time yo scan this channel?
Username: Sump
Post Number: 564
same guy ...
https://www.ecoustics.com/electronics/forum/home-video/594128.html
Username: Born_hard
Post Number: 13
Yes, it was on 97.0°W now is on galaxy 99.0°W
lyngsat say free air
Username: Plymouth
Post Number: 11143
Born Hard
King is right, if it is the first that you scan this channel, now it can be hidden, so you will not get it.
King this satellite seems to have changed all Tp frequencies and SR.
Username: Tapeman
Post Number: 4456
Don't worry
I'll get yo up and running
Nothing born too hard for King
I don't have a setup for 99W at this time but I promise I check for yo
Peace bro
Sorry for hijacking yor other thread
Username: Born_hard
Post Number: 14
Plymouth chanel moved I did factory defult I scaned again
30" dish is now on 99
I did it right chanel comes no video I think is encryptet
Username: Plymouth
Post Number: 11144
Born Hard
Look if you got a signal on this channel, in regard that you had put the PID info manualy, if you doesn't have signal, it was because it's gone or like I says this channel is hidden.
I can't use my VS Ultra to do a scan because my wife is seat in front on this TV set and you know how it is!
My other motorized dish doesn't have the good LNB then is too small to get it.
Username: Born_hard
Post Number: 16
no rush, thank you guys
I did PID same result signal &quality very good
this chanel come from Egypt is it because in PAL
Username: Nydas
Post Number: 16243
It is also on 118.7 Anik F3 at
11989 V SR 20000 FEC 3/4
but is encrypted under N3
Username: Lk__lives
Post: 100mil...
Post Number: 25
