Need Help CHARGING SYSTEM!
Username: Cal1089
Post Number: 58
ok i have a aq1200d and a konaki d2.
my volts are dropping to about 9.5-10 within seconds of using the amp. please tell me the cheapest most effective way to fix this. on the remote it flashes red says CLIPPING? i havent been using it much because i am worried it can damage my amp. please help i have done the big three but i KNOW i need more. would 136 amp be enough i belive mine is a 90?
94 Jeep grand cherokee 4.0 I6
Username: Turnmat
Www.j-designs.org
Post Number: 1097
I would also get a upgrade for your battery as well as your alt. If you have the money the more power you have the better.
Username: Cal1089
Post Number: 60
i really dont have the money to begin with would running an extra battery make any difference?
Username: Southernrebel
Post Number: 7663
How old is your battery?
What size wire did you use?
Upgrade your factory grounds and alt to batt power.
(Big-3)
Username: Van_man
Boston South, MA
Post Number: 4941
no. you need a larger alt. The 136 should be ok. I run a AQ2200 off one., With a second battery.
And you have a good wire run from the alt to the bat? and bat to amp? and good grounds tru out?
It shouldnt be droping that low that fast.
I didnt think that amp would even run at 9 volts...
Username: Cal1089
Post Number: 61
i did the big three with 0 gauge. the batt is\ proabably old. i couldnt tell you for sure. also it seems i get higher volts in the morning when its cold which is weird to me. also any opinions on the best/ cheapest battery?
Username: Van_man
Boston South, MA
Post Number: 4943
the largest diehard is my choice of a budget battery, only cause of the warranty and availability.
I would start with a battery, see how it goes, then look in a junk yard maybe for a dodge truck or van alt. From a V8. Most would be 136. Should get one fairly cheap. Just look for a newer one that has the same bolt pattern and pully set up as yours.
Look for a nippondenso or Bosch
Username: Van_man
Boston South, MA
Post Number: 4944
http://us-dc1-order.store.yahoo.net/cgi-bin/wg-order?ysco_key_event_id=&ysco_key _store_id=motorcityreman&sectionId=ysco.cart&yscoc=g0RYK7UmAUcbquzAcLq5oxoldZLpy XdAEqRFKVa084ylBirQn6bJ_PRULuQGvqIanfFQClBYe_9qJlflVGJl66pE74BoisPPD_lF9gz3KlOrG 6FuRK4HNfhCMOeTbEYwGHtdFxhcPW1GjQ--&yscos=ws5BjwgmAUcKClR3wQm5BLnJkBdzqzStzSxXoQ 23y3F50ee_Xrdyen6JafHKvzj5l4P7SRG7U40RwdcWUlvrIKqEXHW6bHb.pCNCKMaOtcmGE2njBTikJz JhZ_mbHd90CDpQeUh164S5wQ--&yscob=Q5cyR60mAUd1Xd8VluXxMZgslUzPKfvYwuCGcGxUOcSWKnJ 9EGXiFPBjt01_yJ8xuevIEErAcdqthDKnR4gCBp2q7bD2BCIbm.hNGLbXkRzhZipsYZztWRTecPbBa75 Dwg--
Username: Cal1089
Post Number: 62
that link dont work
Username: Th3pwn3r
I compensate...
Post Number: 9409
Look at what you can change.
New grounds.
New power wires.
New, high output alternator.
New battery.
More batteries.
Also, check to make sure current grounds aren't corroded or have shorted out, frayed, come apart or even rusted off.
Username: Cal1089
Post Number: 64
ok so would a new battery really make that much of a difference. i hvae never had a problem before this system but this also is my first system with better quality. idk i just want it too run right
Username: Philly306
You choose to be ignor...
Post Number: 1425
"please tell me the cheapest most effective way to fix this"
turn down the gain. costs nothing but only a few seconds of your time.
looks like i win. all of you just got PWNED
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 3136
Phil ftw.
Your voltage should not be dropping that bad in the first place. My brother runs that same amp ( with a stock 80amp alt and an interstate battery) and his voltage stays in the upper 13s. You probably have a bad ground, or maybe the battery is bad. Get it tested at autozone or something. It also may be a good idea to get your alternator tested.
Finding what is wrong will be strictly trial and error.
