Silver Member Username: Armykyle1Ms Us Post Number: 818 Registered: Dec-08 | http://cgi.ebay.com/Audiopulse-Neo-18%22-Subwoofer,BassMaxx,TC-Sounds-Custom_W0Q QitemZ170339923409QQcmdZViewItem |
Silver Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 805 Registered: Aug-08 | wow bit much |
Gold Member Username: RideredderCornell, IL USA Post Number: 1686 Registered: Sep-05 | Yeah, there's alot of them for sale on CA for cheaper. |
Silver Member Username: DangerangerOhio United States Post Number: 136 Registered: Mar-09 | Will someone explain what a neo is? Are there benefits to using one or drawbacks etc.... |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15488 Registered: Jul-05 | u have to admit it looks so weird i wud love to own 1 since it wud be a hell lot lighter to handle & far less weight in ur ride than a traditional ferrite magnet sub but damn man : that price is a killer ....... ![]() |
Gold Member Username: Philly306You choose to be ignor... Post Number: 1434 Registered: Apr-07 | Neo=neodymium. Nd2Fe13B Lighter than normal ferrite but also more expensive. Neodymiun also has a Higher Mr(magnetism) nomal magnets=ferrite. (2 elements)2O4 heavier more widely used less expensive. lower Mr. These factors are taken into consideration durin the design process so that 99% of the time you wont hear a difference betweent the two. Unfortunately Most think ferrite motors will be louder do to thier size plus its cheaper. |
Silver Member Username: DangerangerOhio United States Post Number: 137 Registered: Mar-09 | alright thanks for the explanation, so is the major difference just weight and magnetism then? sorry to thread jack |
Gold Member Username: Philly306You choose to be ignor... Post Number: 1435 Registered: Apr-07 | yep. Price is by far the biggest factor though. and obviously theier are certain applications where a neo motor would be better suited than a ferrite one. but thats for the listener to decide |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 3149 Registered: Mar-07 | The Neo magnet also contains its magnetic field. Nothing will happen if you stick a key next to it, unlike a ferrite magnet. |
Silver Member Username: Armykyle1Ms Us Post Number: 822 Registered: Dec-08 | X2, it allows you to run a smaller enclosure due to the fact that you have a smaller motor |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3857 Registered: May-07 | ![]() |
Gold Member Username: Philly306You choose to be ignor... Post Number: 1436 Registered: Apr-07 | Although it can be used in a smaller enclosure its not alsways best. Also Neo magnets are very brittle and can corrode easily which is why you see them with the shiny mettalic coats over them. Neodymium is also very heat sensitive. Meaning If it gets too hot no more magnetism and you just ruined a neo motor. This is partly because they aree smaller and therefore have less area to dissapate heat as well as chemical properties that make it not so good in heat. This is why you wont see many neo motors in high power applications without huge heat sinks ot VCs to make up for it. |
Gold Member Username: Wolf_houndPhoenix, AZ Post Number: 1003 Registered: Sep-05 | phil is the smartest black guy i know. |
Silver Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 817 Registered: Aug-08 | haha ![]() |
Gold Member Username: Snowball123West Allis, WI Post Number: 3122 Registered: Oct-07 | Lmao Jules. And you're gold now? |
Gold Member Username: Philly306You choose to be ignor... Post Number: 1438 Registered: Apr-07 | I would like to make a motion to permanantly make jules a silver member as a sign of respect to those who earned thier gold status. do i hear a 2nd? |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 4136 Registered: Mar-07 | lol, I'll second that! |
Silver Member Username: Armykyle1Ms Us Post Number: 828 Registered: Dec-08 | lol that was funny. I still have a while to go. Has anyone see the neo motor setup on the Diamond HEXpro subs? The look sick, http://www.diamondaudio.com/content/view/125/191/ I love it |
Silver Member Username: DangerangerOhio United States Post Number: 138 Registered: Mar-09 | thanks for the explanations |
