Need Help A.S.A.P. 96 Explorer Sport ... CD to mp3 swap , now have no sound
Username: Mccoyxx
Hello everyone , I am at a loss for words on what happened to me earlier today. I purchased a 96 Ford Explorer Sport yesterday and wanted to change the CD player out and put in my mp3 deck. I removed the old Sony CD unit and unplugged the harnesses, then took the Sony mp3 harness and wired everything up. When I tried to test the mp3 unit it came on and lit up and functioned properly, but I had no sound at all . This unit is almost brand new and was working perfectly in my S-10 I removed it from earlier today. I have rechecked all of my wiring and everything is connected color to color on the harnesses, connections are soldered with shrink tubing and no fuses are blown. I ran a seperate ground straight to the battery and checked it and still nothing. The CD player and the mp3 player worked fine until I switched them and when the mp3 didn't have any sound I switched the CD unit back and now it has no sound either. The factory wiring hasn't been cut and all is as it should be except for the sound. Please if anyone knows what is going on here let me know as I am clueless. Thanks for your time ... RSM
Username: Illuminator
Post Number: 5053
Doesn't your car have a factory amplifier?
Username: Mccoyxx
Nope ... no factory amp I don't think ... because the Sony CD player was working when I uninstalled it .... I hooked up some bookshelf speakers to the Sony mp3 yesterday and it works fine ... I am really lost here ... there is however a ground on both wiring harnesses , a black on both ... the one that feeds the power and the one that goes to the speakers too ... I tied both together with the Deck ground from the mp3 and its working fine with the bookshelf speakers?
Username: Mccoyxx
Got it !! ... they had it wired straight to the battery before I hooked it up correctly .... had a factory amp mounted under the passengers side rear panel in the hatch ... took the amp loose and re-wired everything ... works great :-)
