Google wouldent tell me so i have a noob question
Username: Gcs8
if i use this amp http://www.sonicelectronix.com/item_6190_Power+Acoustik+A2400DB.html with two polk momo's and two polk mm's it shuld match up well right? abought 450 watts per? ty for your time
Username: Insearchofbass
York, Pennsylvania
Post Number: 12181
That amp is garbage do not buy it.
Username: The_image_dynamic
San Diego, California
Post Number: 5321
Lemme see if I understand what you are saying. You want to mix two Momo's with two MM's and run all four at 1ohm giving you 450RMS each?
First of all that amp won't do near that, and second of all -- don't mix subs. Get a budget 750-1000RMS amp from Audioque, Phoenix Gold, Orion etc. and just run the best two.
Username: Gcs8
well its gota be better than the kicker 750.1 running them at 4 ohm for the past year. the two different types of subs are in different boxes thet where built for them. tryed just to at 2 ohm's dident sound any where as good as all four. and there the sameish thing just last years and this years. i would also like to know why you think that amp is crap, just asking if you dont mind.
York, Pennsylvania
Post Number: 12189
Its a very cheap brand that says they put out alot more power than they actually do. not to mention the price is high
Username: Gcs8
i am just looking to get closer to the rms of all 4 subs. even if it puts out 1200 rms its better then the kicker at 4 ohm's witch is 350 watts i think. but as i was told each sub takes up a fraction of the power. so 4 at 350 shuld be around 97 watts under ideal condisions. am i right to think that?
York, Pennsylvania
Post Number: 12194
ok lets do it this way what is the rms power rating on each sub and are they single 4 ohm speakers each
Username: Gcs8
the momo's are 400 rms and the mm's are 425 rms and they are all single 4 ohm's. and thank you for dealing with me.
York, Pennsylvania
Post Number: 12195
Ok lets see what we can find you.
Post Number: 5323
Sean did you get the part where he is running two (slight or not) different sets of subs in two seperate and different boxes? MM series and Momo series are not the same. Unless he is talking about the older Momo's that had their models starting with MM? They still have different T/S specs and running two boxes, especially different tunings, is pretty much never good.
Username: Gcs8
the box's are custom made for each set.
York, Pennsylvania
Post Number: 12197
http://cgi.ebay.com/2009-HIFONICS-BRUTUS-BXi1610D-1600W-Car-Amplifier-Amp_W0QQit emZ230376048463QQcmdZViewItemQQptZCar_Amplifiers?hash=item35a37b874f&_trksid=p32 86.c0.m14
or
http://www.vminnovations.com/product_1271/HIFONICS_BRUTUS_BXi1610D_1600W_Mono_Am plifier.html
York, Pennsylvania
Post Number: 12198
I agree but he seems set on running all four.
Post Number: 5324
And by the way I got to hear the new SR series by Polk last week. They are killers for SQ and hit pretty hard too for the RMS. I might put a couple 12's in my buddies car for a reference listening station for studio mixes. As close to that "at home" natural sound as I have heard since the Infinity Perfect and DL-S.
York, Pennsylvania
Post Number: 12199
You know you probably dont have the electrical to back all this power up what kind of vehicle year make and modle
York, Pennsylvania
Post Number: 12200
I recommended a pair of sr's a few weeks ago. i knew polk still made good products.
Username: Gcs8
its a 2010 Toyota camery
York, Pennsylvania
Post Number: 12202
I cant find what size alternator you have but i would bet its not bigger than 90 amps. Id keep the kicker 750.1 its probably the most you can run without problems or electrical upgrades.
Username: Gcs8
Post Number: 7
i have a good mechanic i can make that happen for the most part but i can just run the amp low and watch the voltage.
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3830
Don't mix subs. period. I won't help with anything else till you get that point.
Username: Gcs8
Post Number: 8
i don't get why because no one has told me why i shouldn't....
Username: Nd4spd18
Philadelphia, PA
Post Number: 10661
1) frequency cancellation
2) different reactive loads = not good for amplifier
And im not bothering to explain what that means since im pretty sure this guy wont listen anyways.
Username: Gcs8
Post Number: 9
ok so lets say i go out and get two more MM's for my box thats shaped like an L. because i do wana do this right. watt's / number of subs = output per sub?
