Bronze Member Username: Gcs8Post Number: 13 Registered: Sep-09 | i am thinking of maybe getting some fi ssd or fi q not sure yet. hears my current set up. [IMG]http://i620.photobucket.com/albums/tt289/gcsviii/DSCN0496.jpg[/IMG] [IMG]http://i620.photobucket.com/albums/tt289/gcsviii/DSCN0494.jpg[/IMG] [IMG]http://i620.photobucket.com/albums/tt289/gcsviii/DSCN0493.jpg[/IMG] |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 21226 Registered: Jun-06 | ![]() |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7709 Registered: Mar-04 |
lol This is the undisputed champ of all your posts. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12404 Registered: Jun-04 | x2 |
Bronze Member Username: Gcs8Post Number: 16 Registered: Sep-09 | wow, have I been laughed off this site? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12413 Registered: Jun-04 | not you william robert |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12414 Registered: Jun-04 | what exactly are you looking for sq.... sound quality sql.... sound quality and spl loud spl....mostly just loud and what is your budget? |
Bronze Member Username: Gcs8Post Number: 17 Registered: Sep-09 | ah. i would still think polk would be louder than they are. |
Bronze Member Username: Gcs8Post Number: 18 Registered: Sep-09 | sql |
Bronze Member Username: Gcs8Post Number: 19 Registered: Sep-09 | 300-500 sorry for got to read |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12415 Registered: Jun-04 | what amp do you have? |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1161 Registered: Feb-07 | Its ok. The ssd would be a nice sub. |
Bronze Member Username: Gcs8Post Number: 20 Registered: Sep-09 | Power Acoustik A2400DB |
Bronze Member Username: Gcs8Post Number: 21 Registered: Sep-09 | i am going to move from 4 to 2 12" at least for now |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12416 Registered: Jun-04 | looks like you have about 1200 watts true power out of that amp at 1 ohm so id suggest a fi q sub with dual 2 ohm coils if your buying one. |
Bronze Member Username: Gcs8Post Number: 22 Registered: Sep-09 | 13.8*120=1656 is what i got.. or am i doing math wrong? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12418 Registered: Jun-04 | in that case go with two fi ssd 12's |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1164 Registered: Feb-07 | Just curious why not the BL. Both the Q and the BL are great subs, but wouldn't the BL be more of a sql sub? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12419 Registered: Jun-04 | you have to take off efficiency losses. 13.8 x 120=1656 minus 20% for class d. 331 1325 best case |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1167 Registered: Feb-07 | I dont think anyone asked this but how much room for a sub/s do you have? |
Bronze Member Username: Gcs8Post Number: 23 Registered: Sep-09 | well then i should ask any thing custom i should have done to it? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12420 Registered: Jun-04 | true if you want to go that route go with a single fi bl 18 if you have the room and get the power options |
Bronze Member Username: Gcs8Post Number: 24 Registered: Sep-09 | the box(s) i had built for my polks... so my only guess would be the depth of the sub plus maybe an inch sealed. |
Bronze Member Username: Gcs8Post Number: 25 Registered: Sep-09 | theres a pic of my trunk up top. also thank you for fixing my math |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1169 Registered: Feb-07 | For the amount of power you are running you could just go with a stock BL or you could add everything and get a fully loaded one if you plan on running more power later on |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12421 Registered: Jun-04 | The minimum ported size for the 18 is 5 cubic feet 8 cubic feet being maximum. |
Bronze Member Username: Gcs8Post Number: 26 Registered: Sep-09 | i could fit in 5 cubic feet 0_0 |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1171 Registered: Feb-07 | Sounds like a good setup to me. Should slam pretty good |
Bronze Member Username: Gcs8Post Number: 28 Registered: Sep-09 | its a 2010 Camry if you know what ever that trunk space is. just an odd trunk "mouth" |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12423 Registered: Jun-04 | I agree. |
Bronze Member Username: Gcs8Post Number: 29 Registered: Sep-09 | i also heard that you cant push a sub as hard if its in a ported box.... that 5hit to? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12424 Registered: Jun-04 | get a dual 2 ohm voice coil 18. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1174 Registered: Feb-07 | In the properly designed box you wont have any problems. You just need to make sure the sub doesnt bottom out |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12425 Registered: Jun-04 | it somewhat depends on how large you go with the box for that to become a factor smaller boxes tend to accept more power without reaching suspension limits. Sealed boxes can also react in a similar manner. |
Bronze Member Username: Gcs8Post Number: 30 Registered: Sep-09 | and how would i as a noob do that? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12426 Registered: Jun-04 | what bottom a sub out....by over driving it in too big of a box....your setup wont have those problems though so dont worry about that. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1179 Registered: Feb-07 | Thanks for the clarification Sean ![]() |
Bronze Member Username: Gcs8Post Number: 31 Registered: Sep-09 | so now my noob question is any one wana buy / trade for my 4 polk's? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12428 Registered: Jun-04 | anytime |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1182 Registered: Feb-07 | How much? |
Bronze Member Username: Gcs8Post Number: 32 Registered: Sep-09 | also thank you for answering all my BS |
Bronze Member Username: Gcs8Post Number: 33 Registered: Sep-09 | 60$ for the silver momo's ones 70$ for the black mm's...i think i might be asking a bit much there not shure |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12430 Registered: Jun-04 | Not a problem and welcome to ecoustics |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1184 Registered: Feb-07 | Your welcome. We are here to help and so that everyone that has a question will get a good answer and learn a little something in the process |
Bronze Member Username: Gcs8Post Number: 34 Registered: Sep-09 | i usaly just fix computers and networks so this is one of my extra learning subjects. also thank you for the welcome. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12431 Registered: Jun-04 | Im glad we could help. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1186 Registered: Feb-07 | if i have the money i might buy them. What is the rms on the subs? |
Bronze Member Username: Gcs8Post Number: 35 Registered: Sep-09 | if you really want to laugh i got bored and hooked 2 systems inside the house and out on the back deck... |
Bronze Member Username: Gcs8Post Number: 36 Registered: Sep-09 | 400 on the momo's i think and 425 on the mm's http://www.sonicelectronix.com/item_14748_Polk+Audio+MM1240.html http://www.sonicelectronix.com/item_7096_Polk+Audio+MOMO+MM2124.html |
Bronze Member Username: Gcs8Post Number: 37 Registered: Sep-09 | will also throw in free computer help when needed lol |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12433 Registered: Jun-04 | lol imagine home theater now....i love it |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12434 Registered: Jun-04 | ok thanks ill remember that. |
Bronze Member Username: Gcs8Post Number: 38 Registered: Sep-09 | http://gcs8.serveftp.net/TDP/IMG_1674.JPG best bass in the house |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12436 Registered: Jun-04 | do you have a home theater set up? |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2682 Registered: May-04 | Ok dude I gotta ask........whats in the pill bottle? ![]() |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12437 Registered: Jun-04 | what pill bottle? |
Bronze Member Username: Gcs8Post Number: 39 Registered: Sep-09 | I have a home theater I put to gather with spare car audio. pill bottle is phenergan. just go throw http://gcs8.serveftp.net/TDP/ |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2683 Registered: May-04 | Why do you have phenergan? Are you on any pain killers or any opiates? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12438 Registered: Jun-04 | Cool reminds me of when i got my first home theater all i had was two speakers at first but at least they were true home stereo speakers. Then i hooker up other speakers from other systems i had for the rears. Then used the tv as the center channel. |
Bronze Member Username: Gcs8Post Number: 40 Registered: Sep-09 | i am 5'11'' and 105 pounds i got a fucked up body. and no PK's and just stoped smokeing |
Bronze Member Username: Gcs8Post Number: 41 Registered: Sep-09 | go throw my link (http://gcs8.serveftp.net/TDP/) i have a lot of getto for a scronny white boy. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2684 Registered: May-04 | Just wondering man. Most of the time they prescribe phenergan to help with the nausea and itching caused by opiates. Carry on........ |
Bronze Member Username: Gcs8Post Number: 42 Registered: Sep-09 | i almost feel this should be an aim chat room lol |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12440 Registered: Jun-04 | Im going to hit the bed talk to you again sometime. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2685 Registered: May-04 | "i almost feel this should be an aim chat room lol" This forum has been there done that! lol |
Bronze Member Username: Gcs8Post Number: 43 Registered: Sep-09 | yeah i guess i should head out for the night as well got class at 1:30 |
Bronze Member Username: Gcs8Post Number: 44 Registered: Sep-09 | after food..... |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 45 Registered: Sep-09 | think i should get an eighth order box? when i get the 18"? also how much would it cost to make? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12455 Registered: Jun-04 | No this sub is made to be ported and will have a enclosure large enough as it is. |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 47 Registered: Sep-09 | eather way i will need a new box.. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12456 Registered: Jun-04 | yes |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 48 Registered: Sep-09 | any one in the Atlanta area that makes good boxes? |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 49 Registered: Sep-09 | oh sean, any type of ported box or just box with a hole in it? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12457 Registered: Jun-04 | Make a thread someone from around there should post. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12458 Registered: Jun-04 | tune the box to 33 hz |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 50 Registered: Sep-09 | I I caption |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12459 Registered: Jun-04 | with two 4 inch aero ports 10.5 inches long each port |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 52 Registered: Sep-09 | o_O now you lost me |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12460 Registered: Jun-04 | Where to get the 4 inch aero ports. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-352 |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 54 Registered: Sep-09 | so noob question... why so long? or why this over slot... my braid is stealing your ideas..... |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12461 Registered: Jun-04 | to save space otherwise the box will have to be alot bigger than 5 cubic feet....thats actually not long for a 33 hz tuning. |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 55 Registered: Sep-09 | oh. well that's nifty. now I just need to figger out how to squeeze this in the oddly shaped Camry trunk. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12462 Registered: Jun-04 | The flared ports flow a decent amount more air than a standard round port. Ive seen what two 4 inch aero ports can flow....plenty. |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 56 Registered: Sep-09 | you already sold me don't make me max out my card to do this now. and then i had the thought of porting my trunk in to my cab area. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12463 Registered: Jun-04 | ok here we go go to lowes or someplace like that and have them cut your pieces to the desired demensions off of this program. skip the port demensions. http://www.reaudio.com/speaker_box/LPort_Box_Calc.html let me take a look at what you have then. all you will need to build the box then is a jigsaw for the speaker cutout and a pre drill bit and a cordless drill screws and sealer |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 57 Registered: Sep-09 | ohh thank you. but also what a bought my idea of using my rear 6x9's holes that are empty and in the trunk area and put the same port tubes throw those as a odd second box / cabin pass throw. ?_? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12464 Registered: Jun-04 | make the cutout the given cutout dimension |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12465 Registered: Jun-04 | take the 6x9s out and let the box breathe that way without port tubes through the holes |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 58 Registered: Sep-09 | already doing that |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 59 Registered: Sep-09 | and will an uber drimmel do the job? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12468 Registered: Jun-04 | not sure what that is. |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 61 Registered: Sep-09 | http://www.powertoolsuk.co.uk/webcat/details.asp?ProductCode=RZ5&ID=5016 |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12469 Registered: Jun-04 | looks like it might work |
Bronze Member Username: Gcs8Atlanta, Ga Post Number: 62 Registered: Sep-09 | never asked a bought a new HU |
