Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12096 Registered: Jun-04 | I decided im going sq with my car instead. It fits my true goal with music and saves my hearing. |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15455 Registered: Jul-05 | i bet it saves weight in ur ride & gas $ too ...![]() |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12098 Registered: Jun-04 | Ha ha you bet. |
Gold Member Username: BernymacPhnom PenhCambodia Post Number: 4733 Registered: Sep-04 | Buy my ap axis for your sq goals ![]() |
Gold Member Username: BernymacPhnom PenhCambodia Post Number: 4734 Registered: Sep-04 | Knowing you Sean, you probaly have something you can trade with me. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12100 Registered: Jun-04 | I already have two subs that are competing for my sq sub. The image dynamic idq 12 and the rd sq 12. They get loud enough for what i need. Thanks though. |
Gold Member Username: LoudonPost Number: 2989 Registered: Jun-04 | trade u a sonance for it berny ![]() |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7228 Registered: Nov-05 | im curious as to which h/u-processing you will use along with which front comps.. also 2way or 3way active? |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7229 Registered: Nov-05 | damn no bump ftl |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12101 Registered: Jun-04 | I have an eclipse 3100 cd player diamond hex comps 5.25's 2 ways that will be run on a rainbow craftworks amp |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12102 Registered: Jun-04 | I have an eclipse 3100 cd player diamond hex comps 5.25's 2 ways that will be run on a rainbow kraftworks amp |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12103 Registered: Jun-04 | Im thinking ill need some midbass. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12104 Registered: Jun-04 | . |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12105 Registered: Jun-04 | I just bought my midbass. 69.99 shipped a set. CL-6E - CDT Audio Classic Series 6.5" Mid Range Drivers * Diameter: 6.5" (170mm) * Sensitivity: 90.8 dB * Power Handling: 80 Wrms (100W pk) * Frequency Response: 60 ~ 5000 hZ * Nominal Impedance: 4 Ohms * Voice Coil Diameter: 1.0" (26mm) Dimensions * Mounting depth: 2.63" (66.8 mm) * Cutout diameter: 5.78" (147 mm) * Outer diameter: 6.63" (168 mm) Thiele-Small Paramters * Free Air Resonance: 67.4 Hz * Voice Coil DC Resistance: 3.59 ohms * Voice Coil Inductance @ 1 kHz: 0.19 mH * Mechanical Q (Qms): 3.56 * Electrical Q (Qes): 1.08 * Total Q (Qts): 0.83 * Compliance Volume (Vas): 8.73l / 0.308 ft3 * Moving mass, Diaphragm: 15.81 Gr * Driver Radiating Area (Sd): 133 cM2 / 20.57 In2 * Motor Force Factor: 4.71 Tm Note: All sealed boxes greater than 0.6 cubic feet are useable but the response effects will suit special purposes. Usably small enclosure setup for bass in a medium size cab is shown here. |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1729 Registered: Aug-07 | from where? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12110 Registered: Jun-04 | http://www.woofersetc.com/p3618/CL6E--CDT-Audio-Classic-Series-65"-Mid-Range-Drivers.htm for 69.99 but here for 59.99 http://cgi.ebay.com/CDT-AUDIO-CL-6E-Classic-Series-6.5%22-Mid-Range-Drivers_W0QQitemZ110429235011QQcmdZViewItemQQimsxZ20090829?IMSfp=TL090829184002r26112 |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7232 Registered: Nov-05 | not to hate.. but you just got a midrange driver.. not a midbass driver |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12112 Registered: Jun-04 | Yeah I just realized that. I can cancel tomorrow. Thanks for lookin out. |
Gold Member Username: Van_manBoston South, MA Post Number: 4930 Registered: Mar-06 | So, What Did you decide on for a midbass? 6" or 8"? Are you mounting in the kicks or door? where are the hex's mounted? Interested in some pics when your done.. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12113 Registered: Jun-04 | Well I bought the wrong size hexes I have the 5.25 when I should have gotten the 6.5's but im going to use them anyway because I spent enough on them. Im going to wait on the midbass untill I get my system installed with what I have already. Im mounting the hexes in the door. Ill take some pics since I got a awesome pentax 12 meg to do the job. Im also building a new box for my image dynamic idq 12 .55 sealed and a box for my rd sq 12 1.00 cf sealed and see who wins for the subwoofer department. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12115 Registered: Jun-04 | I went with a a pair cdt m6plus for the midbass. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12116 Registered: Jun-04 | I picked up some diamond audio coaxes for rear fill (for me) not for sq comp. Looks like ill be running the rainbow amp on the diamond hexes and a phoenix gold xenon 200.4 on the midbasses and coaxes and a phoenix gold xenon 400.1 on the sub. So three amps total. |
Gold Member Username: Van_manBoston South, MA Post Number: 4932 Registered: Mar-06 | Nice Choice Sean. Read some great things about those. Heres a great read on some install pointers for them as far as xover points and slopes. http://www.mainstreet-audio.com/cdtaudio/cdt_m6_midsub_bass_driver_review.htm Im not crazy about the red.. But whos looking. Im in the process of redoing my pods. Going all Beyma, 2 pairs of Power W6 2 pairs of Power M6 And PH-35 tweeters. I have it all sitting, waiting..... |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12117 Registered: Jun-04 | Thanks. Sweet stuff you got there. |
Bronze Member Username: 813thumperTampa, FL United States Post Number: 60 Registered: Sep-09 | Do you have a picture of your old wall. I would love to see one. Ive been considering a wall in my car. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12466 Registered: Jun-04 | I never did put a wall in my car at all. want to buy the subs i was going to use i have them brand new in the box ....phoenix gold rsd 12 dual 4 ohm coils....i have 8 of these subs. |
Bronze Member Username: 813thumperTampa, FL United States Post Number: 61 Registered: Sep-09 | oh ok I see. nvm then. |
