Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1196 Registered: Jan-08 | I'm looking for some good, yet relatively inexpensive deadener. Whats good? Edead, dynamat, what else is available. |
Silver Member Username: Mpinto19kDallas/Fort Hood, Tx Post Number: 281 Registered: Feb-09 | I went with Second Skin Damp Pro with mine and am very satisfied, never heard the regular SS compared to pro but this site helped me make a choice. http://www.sounddeadenershowdown.com/cgi-bin/index.cgi |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3901 Registered: May-07 | fatmat is great for the price. Ebay can hook you up. |
Silver Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 836 Registered: Aug-08 | i'm planing on to use 2 or 3 layers of Second Skin thou out my whole cab and the spay in bed liner for the bed of the truck, and has anyone used spary in bed liner or Deadener under the truck? |
Gold Member Username: TejcurrentPost Number: 1944 Registered: Apr-07 | I used Spectrum. You need to spend plenty of time prepping the surface and masking off overspray areas.Remove all debris and oil/grease first, otherwise it flakes off. I cleaned one spot, it's holding perfect, left another dirty and it flakes off in 3-4 days. I'll never use anything other than Second Skin. |
Silver Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 838 Registered: Aug-08 | tory how much does it make a diff with Deadener to with out? i'm really hoping to cut out road nosie/exhaust nosie? |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3902 Registered: May-07 | That is it's purpose. Should make quite a difference. |
Silver Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 842 Registered: Aug-08 | lol yeah i just want to know were to put my hopes at, |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1197 Registered: Jan-08 | Im thinking either fatmat or eDead. Which should I go with? |
Gold Member Username: Dustin3D&L Audio Tech.Dustin Post Number: 5104 Registered: Oct-05 | go with edead Kevin. Can't go wrong with it. |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3911 Registered: May-07 | Kev. I can say that Fatmat does it's job..Here's my way of showing you the difference. http://www.youtube.com/watch?v=DKn9in3aN-U&feature=channel_page 1st vid is my setup before the 5750 and fatmat. was added. Was doing 147's and notice the flex problems.. http://www.youtube.com/watch?v=BynSXTkHCsU&feature=channel_page This video is same song but running the 5750 and after fatmat. I was hitting 150+ and notice the difference in flex even with the added power. |
Gold Member Username: Snowball123West Allis, WI Post Number: 3134 Registered: Oct-07 | Save up and get SecondSkin. Only need one layer then. If you think about it, you'd probably be saving yourself money, rather than putting a couple layers of eDead in. |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1198 Registered: Jan-08 | Where can I get second skin from? I really dont have all that much flex... nothing like Mark's suv lol. I just want to reduce vibration and hopefully gain some all important deebeez. |
Gold Member Username: Snowball123West Allis, WI Post Number: 3135 Registered: Oct-07 | secondskinaudio.com |
Gold Member Username: HdubbTeam Revolution Post Number: 4233 Registered: Nov-04 | second skin damplifier pro is the best mafu.ckin sh.it ive ever used kiddos. if that means anything to you guys lol |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 802 Registered: Nov-07 | Second Skin wins. Don't even look at anything else. |
