hi i have a 05 corsa with siemens vdo cdr 2005 player in it i have the serial number gm020543417164 and i need the code because its in safe mode thanks in advance
Unfortunately the majority of SIEMENS/VDO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
