What do I do?????
Username: Jkd_360
Port Angeles, WA USofA
I have
subwoofers-
one - Fosgate 12" T1,
600w-rms/1200w-peak @ 2 or 4 ohms (not sure of t112d2 or t112d4)
two - Alpine type swr-1242
500w-rms/1200wpeak @4 ohms
Amps-
Pioneer GM-D510M
Class D Mono
Peak Music Power 1000 Watts
Number of Channels 1
Load Impedance Capability 2 ~ 8 Ohm (Mono)
Continuous Power (4 ohm) 300W x 1
Continuous Power (2 ohm) 600W x 1
Continuous Power Bridged (4 ohm) N/A
Frequency Response 20 ~ 240Hz
and
Brutus HIFONICS BXI 1280D
Class D Mono
4 ohm 450 x1
2 ohm 900 x 1
1 ohm 1200 x 1
1/2 fard walmart capacitor
Wires ran for two amps
I currently have the Fosgate/Pioneer setup active.
What should I hook to what?
I.E. - Dropping ohms bridging, crossover etc.
I'm new to this so please help me out. I have custom boxes and can get whatever it takes.
Thank you.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 73
What i would do is wire your 2 type rs to 1ohm like this http://www.the12volt.com/caraudio/woofer_configurations.asp an use your hifonics amp (1200x1 @1ohm)
Username: Jkd_360
Perfect! Thank you!
