New member Username: MubyacejrSharjah, U.a.e United arab ... Post Number: 1 Registered: Sep-09 | hello, hi everyone.please can anybody help me with a radio code for my 2006 honda civic vti 1.8 -vtec model? my radio serial number is u3001 L2115. thanks. my email queensboulouvard@hotmail.com |
Gold Member Username: RegroosterPost Number: 1886 Registered: Aug-08 | HONDA RADIOS.................IMPORTANT NOTICE PLEASE READ BEFORE POSTING ANY CODE REQUEST ============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on Please note: The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy HONDA radios are made by the following manufacturers ALPINE AUTOSOUND BLAUPUNKT CLARION KENWOOD MATSUSHITA PIONEER The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing UNFORTUNATELY ... NO OTHERS ! So you will be wasting your time posting code requests here for any other make. BLAUPUNKTS ONLY with a BP Serial Number ================================================= For EVERY other HONDA radio made by one of the other manufacturers then visit the website below https://radio-navicode.honda.com If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM) |
New member Username: Waldo0420Post Number: 1 Registered: Sep-09 | hi,my father in law got a new battery for his 2007 hona ridgline and now tha stereo is lock and he dnt have his code is there any way i can get the code |
Gold Member Username: RegroosterPost Number: 1887 Registered: Aug-08 | Please read the previous message referring to Honda Codes |
