Looking to upgrade my subs.
Username: Sam707
Well I have two 10 inch punch p3's by RockFord Fosgate, but they arent slappen hard enough for me. Whats the best sub I can get for around $200 to get me the most bass possible. I was looking at a kicker l7 15. What do you think?
Username: Turnmat
Www.j-designs.org
Post Number: 1212
What is your max budget and what kind of amp?
Are you going to upgrade your amp?
Username: Sam707
The least possible with good bass. About $300-400?
Username: Turnmat
Www.j-designs.org
Post Number: 1214
You can get a AQ SDC2.5 15" for $170
And a AQ 1200D for $250
That will pound in comparison to your p3's and it will have good sq.
Then later on you can add a second 15 if you have the room for it.
