2004 dodge ram double cab
Username: Redliner
Wilmington, Ma
Post Number: 5096
Hey guys im back just got a new truck for work. Since ive always had cars I dont really know what to do with it lol. I dont want to take up the whole back seat of the truck but need to throw something back there. Any help on a box under the seats or something even just tips would be great thanks guys.
Username: Texas_bass
Houston, TX
Post Number: 691
well you could always get a prefabed box that would fit under the rear seat with 2 10s or12s and an amp wont be the hardest hitting but it would sound nice and u really wouldnt have to mount or modify anything and it would be easy to remove but no one is a fan of prefabed boxes lol
Username: Msand951
San jacinto, Ca Usa
Post Number: 195
I have a 2003 quad cab so does my bro in law. He got a prefab box with 2 12s and it sucked. now he has a w7 in a custom box taking up space for 1 seat in the back. As for me my box might take up two seats.
A stereo shop guy gave me a idea of cutting the carpet and stuffing from underneath the back seat. to give you more cu in. and instead of a box get a carboard cutout of the surronding edge trace it on 3/4 mdf. cut it out then just bolt that to the edge around the metal . so its just the top and all of the bottom use dynamatt or something similar. Hes done it on a bunch of trucks and sounds way better i would go with tens.
so if your going to do the underneath seat thing this is the simplest thing you could due and cheaper. than a prefab box and better. Steve from RD audio has some great deals on some subs this week .
Username: Drant19
DUB-C, TX
Post Number: 2005
blowthru...
Username: Redliner
Wilmington, Ma
Post Number: 5098
ya I dfont think so abarca lol def the best option but need the back for work lol. I will not do prefabs either waste of space. Id rather make one myself that can go under the seat ill start trying to figure it out might just put one 10 or 1 12 under the seat see how much space I have first.
Houston, TX
Post Number: 694
im not to sure but i think on those u can fit a 12 but i know u can ger lots of nice sound with a 10
and told ya no one likes the prefabed boxes
Username: Redliner
Wilmington, Ma
Post Number: 5100
I just hope I can figure something out lol. I would just build my own box never a prefab waste of a sub basically.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3723
My friend has a 4 door SRT-10 that we are trying to do a substage in... Looking at 2 shallow mount 10s ported, Ill let you know if we do it anytime soon.
Username: Van_man
Boston South, MA
Post Number: 4933
Thats a tite cab...as suggested, use cardboard and tape to "hack in" the size of a box that would work..
JL makes one for it, but its $$$$
Username: Insearchofbass
York, Pennsylvania
Post Number: 12120
Go with a sound splinter rli 10
Optimal Car:
0.65 cu ft net volume sealed
0.45 cu ft net volume vented, Fb = 27 Hz
Username: Redliner
Wilmington, Ma
Post Number: 5101
ya jake def let me know. And sean thats a good suggestion ill look into it. Marc I cant afford jl boxes lol good idea though lol
Username: Armykyle1
Ms Us
Post Number: 748
will he have the depth for an rli?
York, Pennsylvania
Post Number: 12145
We shall soon see.
Username: Redliner
Wilmington, Ma
Post Number: 5102
yes we shall i need to measure under the seat the trucks getting some work on it right now so ill let you guys know lol
Username: Van_man
Boston South, MA
Post Number: 4951
check this out..
http://www.dodgetalk.com/forums/showthread.php?t=219571
Username: Redliner
Wilmington, Ma
Post Number: 5104
thats pretty cool marc to bad mine doesnt have that lol ill take some pics in a min and get the dimensions for you guys
Username: Redliner
Wilmington, Ma
Post Number: 5105
def a tight fit in that cab. the dimensions arent exactly straight forward either. It slopes up in the back and curves in on the sides. So from front to back its 6 inches on the sides and 7 inches in the middle. The width is roughly 12-13. the height is
8 3/4 in the back and 10 1/2 in the front I have 2 of these openings on each side and in the middle theres pretty much no space. So most likely this is not gonna be fun to build and try to come up with the right dimensions and cuft size lol. Im thinking of just sticking with sealed since I have pretty much no space.
Username: Redliner
Wilmington, Ma
Post Number: 5106
im waiting on the pics to upload lol
Username: Redliner
Wilmington, Ma
Post Number: 5107
http://s279.photobucket.com/albums/kk146/dafoe348/?action=view&current=newdad461 .jpg
this link should bring u to the pics. sorry kinda tough to take pics of it lol
Username: Redliner
Wilmington, Ma
Post Number: 5108
ya marc im slowly thinking about that center console I just dont wana rip out the center seat in the truck lol i kinda like it. So does my fiance lol.
Username: Armykyle1
Ms Us
Post Number: 814
I say center console box. Gives you a lot more options
Username: Redliner
Wilmington, Ma
Post Number: 5109
ya except then i lose a seat. Which i really like that seat for diff reasons im not to big only losing sitting room
