Silver Member Username: Pu_da_mundaPost Number: 174 Registered: Feb-07 | Hi Guys, I am missing few indian channels on Nfusion Solaris, Zee Cinema, Max, Set Aisa, How to scan these channels? |
Gold Member Username: Saqeeb9000Post Number: 5864 Registered: Oct-07 | here is how you do it sidhu For Example if you are going to add channel 682 on 118 Anik With your remote press Menu---> Installation--->Channel scan Select Satelite 118----> Add tp Enter Frequency 11715--->Polarization= Ver--->Symbol Rate 20000 press ok press search channels here is where u find freq for each channels http://www.lyngsa*t.com/packages/dish119.html remove * this website is not allowed here, so u have to remove * in order to access the website, website have all the freq and tp's for 118.8 west channels enjoy |
Silver Member Username: Moe948Post Number: 112 Registered: Jun-06 | There are probably some missing transponders. You would have to add them manually. |
Bronze Member Username: El_toro_the_greatNC USA Post Number: 12 Registered: Jul-09 | The indian channels are on Anik F3 at 118.8°W http://www.lyngsat. com/anikf3.html |
New member Username: VerdiPost Number: 4 Registered: Jun-06 | Is it true most of international channels, especially arabic channels, are not working on nfusion phoenix with fix 153. Can someone confirm this please, would be very appreciated. Thanks |
Platinum Member Username: PlymouthCanada Post Number: 10842 Registered: Jan-08 | It seems that Nfusion play with the card sharing source to protect the servers, wait and those channels will come back again. ![]() |
