I bought Kbox Pro and hook up everything right. Still my Khub is not connected. When I connect to my friend home working fine. I have linksys router and netgear cable modem. Is it linksys router has problem with Khub? Do I have to buy new router or is there any solution for this?
yes I am pluged into router. Thanks. now I know what is problem. I have VOIP phone and it was connected between router and modem. I reroute and put after router and it is working now.
If it's working well in yor friend's house Are yo pointing yor dish to same satellite?
If yo provide detail information like what dish installed DISEqC, dish antenna settings etc. we may get a better idea than simply say it doesn't work I doubt if it's a router as it is much simpler than FTA receiver to dongle to Dish Antenna with all critical installation setups Everything possible However greater chance is yor installation
I'm assuming yo are using same k-hub and receiver in both houses
