Ipod to two amps?
Username: Bananazebra
Hi all,
I posted last week about connecting two amps together, but was strongly advised against it (something about blowing up...).
What I am trying to do is simultaneously use two amplifiers with one Ipod, connected with a headphone jack.
I figure if I can get a headphone jack that goes into two sets of RCA connectors (4 RCA's total), then I should be able to.
I am trying to achieve as much volume as possible.
Thanks,
Jake
Username: Imalik
15 FI BL SAZ- 1500=Boom, New Jersey Jerzee Playa
Post Number: 675
lol
Username: N2audio
Lawrence, Ks USA
Post Number: 1795
if you can find an adapter to get an rca pair (L/R) out of your ipod then you should be able to use y cables to get signal into 4 amp channels.
Username: Kelly123
Post Number: 9
Yeah, you can buy iPod Auxiliary Input, it support ipod, and control from your car audio panel, it 's easy to install and use. more detail, you can see below
http://www.car-cd-changer.net/product1.aspx?id=23
