Silver Member Username: 2000celicaRoanoke, VA U.s. Post Number: 154 Registered: Jan-08 | Years ago I had 2 12" Fosgate Punch HX2's in a sealed enclosure. I foolishly got rid of them and would like to know if anyone knows where I may be able to get ahold of a set again. I would prefer new, even though I know they are no longer being made. If I can't get ahold of another set, what would be comparable subs to these. I was pleasently pleased with the sound and quality of these subs. I played them hard for years and they never once gave me any trouble and always sounded great. Thanks in advance for any advice. ![]() |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15431 Registered: Jul-05 | unless some of those have been accidentally left in some ware house somewhere its very unlikely to find those new again - very rare but possible try ebay or google to see if u come up lucky for a good pair even if its used if u cant find any , look at the lower series subs from treo engineering - sound from those is pretty close to a Hx2 ... |
Silver Member Username: 2000celicaRoanoke, VA U.s. Post Number: 155 Registered: Jan-08 | Awesome, will do. Thanks. |
Silver Member Username: 2000celicaRoanoke, VA U.s. Post Number: 156 Registered: Jan-08 | Would you say the RE Audio SE model subs are comparable as well? |
New member Username: HuricainePost Number: 6 Registered: Aug-09 | I've seen POWER hx2(higher up) on ebay... http://shop.ebay.com/i.html?_nkw=hx2&_sacat=0&_trksid=p4999.m270.l1313&_odkw=kic ker+l7&_osacat=0 |
