Ohm problem amp is not doing one ohm like it suppose too, only does 4
Username: Qulin
Qulin, Missouri United states
Post Number: 7
ok i have a hifonics bxi1610 4ohms-500, 2ohms-1100 and 1ohm-1600 its on a 2ohm dual voice coil 12'' L5 when i have it wired for 1 ohm, positive to positive, negative to negative you can barley feel it moving but when i have it hooked up 4ohm it hits hard but i know my sub can handle way more hifonics dont put out all there rating so i need to know why it aint working at 1ohm
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2762
What gauge wire do you have for power and ground? Does your ground have a good connection (aka proper area, sanded, secure).
Username: Drbizerk
Okc, Ok U.s.
Post Number: 8
use a multi meter to make sure its actually @ 1ohm
