Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15436 Registered: Jul-05 | http://forums.trinituner.com/forums/viewtopic.php?p=3769235#3769235 ...... ![]() |
Gold Member Username: Livin_loudCOD4 Addict Post Number: 2909 Registered: Jan-06 | arrr good craftsmanship as usual Rovin |
Gold Member Username: Drant19DUB-C, TX Post Number: 2009 Registered: Aug-07 | you do a lot of boxes for type-rs, and non of them have been less than top notch!! A+ Rovin. clean install and i like the way the box fits in the wagon. lots of space still. i bet it sounds great! |
Silver Member Username: WickedbassNashville, Tn Post Number: 849 Registered: Jan-08 | Looks good man! Imma prank call you. ![]() On second thought, the charges would kill me... |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 331 Registered: Dec-08 | if you woulda put an area code on it i woulda =| |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15438 Registered: Jul-05 | im in a country close to Venezuela so that phone call will cost u ...lol thanks guys ..... ![]() |
Bronze Member Username: JbpittPittsburgh, Pa. Usa Post Number: 50 Registered: Jul-09 | Rovin i see u deal alot in type rs, box looks good. I got a question, i have 3 type r 10s i wanna run in a slot ported box. This is the prefab box i have for them http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20177 I know having 1 built is the way to go,but will they sound ok in this box? |
Silver Member Username: CozceSt. Louis ILLside, Pronounced: ... U.S.A. Post Number: 833 Registered: Mar-08 | Nice. |
Silver Member Username: EricmbWaycross, Georgia United States Post Number: 115 Registered: Nov-08 | thats a crazy nice box rovin.. |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15442 Registered: Jul-05 | thanks guys Sean P - it looks good in that picture but whats it tuned to ? a quick check shows 4.9\3 = 1.6cuft \ sub which isnt bad but is that after sub & port displacement ?... |
Bronze Member Username: JbpittPittsburgh, Pa. Usa Post Number: 51 Registered: Jul-09 | The box is acually built realy solid,i was supprised. Im not sure what its tuned to, how do i figure it out? Ive always used sealed, dont know anything about ported, tuning. |
Gold Member Username: Drant19DUB-C, TX Post Number: 2013 Registered: Aug-07 | @ Sean P: that box seems too small...i wouldnt think it would be tuned in the mid or low 30s like you would probably want.. |
Bronze Member Username: JbpittPittsburgh, Pa. Usa Post Number: 52 Registered: Jul-09 | That sucks! How do i figure out what its tuned at? Its nice for a prefab box hate to just throw it away. What would i want a box tuned at if i get 1 built? |
Silver Member Username: DangerangerOhio United States Post Number: 129 Registered: Mar-09 | Sean P. Sell your prefab and like Abarca said tune it in the low to mid 30's. |
Gold Member Username: Drant19DUB-C, TX Post Number: 2014 Registered: Aug-07 | if theres one person on here to ask about box specs for type-r's...its Rovin. i would say hes built wayy more boxes for them and knows what they perform in best.. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12069 Registered: Jun-04 | Looks nice as always Rovin. |
Silver Member Username: Jd93kidBrandon, MS U.S. Post Number: 170 Registered: Jul-09 | yeah.. hey rovin do you have AIM or AOL or Gmail chat or anything.. |
Platinum Member Username: Nyyfan13Northern VA Post Number: 11583 Registered: Jul-06 | Nice box as always Rovin. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9390 Registered: Jul-06 | Good job Rovin. |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15446 Registered: Jul-05 | thanks guys no i dont use aim , msn or aol yes i did try alot of stuff when i had my pair of 12s a few yrs ago - honestly its a sub u can toss in any box & it still sounds good its my 1st time with 10s though im supposed to a 15" in it for a guy in a few wks time - never did a 15 b4 so im looking 4ward to that .... |
Silver Member Username: Armykyle1Ms Us Post Number: 732 Registered: Dec-08 | good review man, I've yet to hear a type R setup that didn't sound good. Hey wats the diff between the ones with ribbed surrounds and round ones? |
